How To Attach Deck Stairs To Lower Deck? - Building & Construction - DIY Chatroom Home Improvement Forum
Old 06-19-2012, 02:43 PM   #1
Rewards Points: 410
How to attach deck stairs to lower deck?
I'm building a 2 level deck, the top deck is 5' above the lower deck with stairs leading down.
I know how to attach/adhere the stairs to the top deck, but how does one typically attach them to the lower? All the books and articles I've seen that have stairs they always end on earth, not another deck.
Do I need supports under the lower deck where the stairs attach? Or can I do something such as space my joists 10-12" oc under the stairs for extra support? I included a picture of what my plan is. Thanks
Piedmont is offline   Reply With Quote
Old 06-19-2012, 09:01 PM   #2
Residential Designer
AndyGump's Avatar
Rewards Points: 664
Send a message via Skype™ to AndyGump
My personal preference is to block between the stringers, laying the block on the flat on top of the lower deck deck-boards.
The blocking will be nailed (or screwed if you prefer) to the deck-boards and then nail through the stringers into the blocking.
Simple.
Andy.
Residential Drafter/Designer
www.draftinginoc.com
AndyGump is offline   Reply With Quote
Old 06-20-2012, 08:10 AM   #3
AHH, SPANS!!!
Rewards Points: 1,166
if the underside of the stairs will be exposed from around the sides of the lower platform then you might want to put the decking down on the lower deck and then set the stairs down on the finished decking just as you would do on dirt. if under the stair exposure is not an issue then still deck the lower deck but just go a few deck boards under where the stairs land to give the stair stringers something to sit on.
hand drive is offline   Reply With Quote
Old 06-20-2012, 10:02 PM   #4
I'd throw a double under where the stringers will land. I notch the bottoms of the stringers to accept a 2x4 or 2x6 flat in the front of them. I'd deck the lower, run the stringers (with the 2x attached) and screw down through the 2x to framing.
Tham
Tham is offline   Reply With Quote
deck stairs Jeremy Hillary Boob, PhD Building & Construction 7 11-22-2011 06:01 PM
spiral deck stairs requirements Jeremy Hillary Boob, PhD Building & Construction 12 07-15-2011 03:26 PM
Deck: how to attach stringers 10Thumbs Building & Construction 6 06-08-2011 01:35 PM
Deck stairs brcocar Carpentry 11 05-09-2011 10:50 PM
Deck Stairs bajaboy1 Building & Construction 35 06-13-2008 05:40 AM
