Old 05-07-2009, 06:57 PM   #1
Question
how to attach composite deck to steel
I built a steel frame boat dock. I want to construct the deck with composite material. Are there self-tapping bolts or screws that will penetrate the composite material, drill the steel (1/8") material and sink the head into the composite?
TazPapa is offline   Reply With Quote
Old 05-07-2009, 08:41 PM   #2
Master General ReEngineer
Bondo's Avatar
Ayuh,... You might have to pre-drill the boards, but, Ya that's Real Doable....
Old 05-31-2009, 08:39 PM   #3
Been there Done That
Send a message via Yahoo to DigitalDreams
The screws your referring to are called tapcons they have a drill bit like end.
DigitalDreams is offline   Reply With Quote
Old 05-31-2009, 09:45 PM   #4
Lic. Builder/GC/Remodeler
AtlanticWBConst.'s Avatar
I hope that the steel boat dock is Galvanized.
Aside from that, generally, when attaching wood/composite finish stock/framing/deck boards - to a steel frame, the process is to install (solidly through mechanical fastening) a wood sub-frame at 16" OC. - to the Steel frame.
In this case, you would use Pressure Treated stock for the subframe material.
Then, the finish wood/composite product/deck boards - are attached to that, using conventional SS deck screws.
Also: You need Stainless Steel fine-thread fasteners/lags/threaded bolts - to attach the PT wood subframe to the galv. steel framing.
- Build Well -
Tags
composite deck, self-tapping bolt
Building new deck and screened in Gazebo - Wood or Composite? Todd1 Building & Construction 10 11-05-2010 12:24 PM
composite deck boards rcassidy Carpentry 7 04-24-2009 09:24 PM
composite vrs. wood deck materials rcassidy Building & Construction 2 04-20-2009 07:33 PM
Composite deck building question Big Marino Carpentry 6 12-31-2008 11:14 PM
