How To Attach An Addition To An Existing Building? - Building & Construction - DIY Chatroom Home Improvement Forum
Old 02-05-2011, 11:03 AM   #1
How to attach an addition to an existing building?
I would like to build an addition to an existing building, the existing load bearing wall is at eight feet with a truss roof. I need to go higher that this to get the right pitch for the addition. How do I attach to the load bearing wall(raise it)? Any ideas? I'm planning to run the roof over the existing to make a smooth transition(good drainage).
wingchunbrother is offline   Reply With Quote
Old 02-05-2011, 11:07 AM   #2
Experienced
Jackofall1's Avatar
You would be well served to sketch a drawing up, many times the answers come much easier if you have a visual key to look at, it would also help the forum if you posted that sketch to visualize what it is you are trying to accomplish.
Mark
The Following User Says Thank You to Jackofall1 For This Useful Post:
wingchunbrother (02-05-2011)
Old 02-05-2011, 11:23 AM   #3
Framing Contractor
You frame the kneewall right on top of the existing top plates and nail the studs into the side of the trusses. It also depends how far out your going and the length/span of the rafters. What size opening are you going to have from the existing wall to the new addition?
Joe Carola
Joe Carola is offline   Reply With Quote
The Following User Says Thank You to Joe Carola For This Useful Post:
wingchunbrother (02-06-2011)
Old 02-05-2011, 11:49 AM   #4
Kneewall is the term? This will help, thank you.
Old 02-05-2011, 11:52 AM   #5
Framing Contractor
Kneewall is the small wall that the rafters can sit on if the trusses cannot handle the weight of the new roof. How far out is the addition?
Joe Carola
Old 02-05-2011, 12:34 PM   #6
Rewards Points: 5,336
And when the water hits the kneewall at the bottom of the roof slope, how do you plan on keeping the water out of the house?
You might want to look around the neighborhood for ways to do this that incorporates both roof lines. Maybe speak to an architect about proper plans that addresses both ascetics and structural considerations.
Ron
The Following 2 Users Say Thank You to Ron6519 For This Useful Post:
AndyGump (02-06-2011), wingchunbrother (02-06-2011)
Old 02-06-2011, 12:56 PM   #7
I under stand what your saying, I have some drawings in the works, but to finish them I needed to make sure how I would tie into the existing load bearing wall. I had all ready thought about the kneewall Idea but did not know the term to use. I looked into blueprints but was given a price of $1600.00, this seems very high or a addition of a storage room to a detatched garage. five pilons, Wood floor 16X40, one or two windows, one door, three walls, a few sky lights, a couple of lights and a roof. most of the plans drawn to scale only thing would be makeing sure its all to code. What do you think?
Old 02-06-2011, 01:08 PM   #8
Framing Contractor
Like I said to Ron in my last post that for no reason at all was deleted, you don't have to worry about that, that's what they make tarps for. The kneewall gets framed and at the end of the day you tarp it. That keeps your house water tight. That's a none issue as far as drawing the plans and presenting them to the town.
Framing it and keeping your house water tight depends on you and how much framing experience you have and how much help you have .
Are you saying that you're going out 16'?
What is the pitch of the existing rafters?
What size rafters on the addition?
If you tell me how far out the addition is and the pitch you want is, I can draw it real quick for you and give you a cross section of what you need.
Joe Carola
Old 02-06-2011, 01:09 PM   #9
I think many localites require a signed plan from an architect or engineer before you get the okay to pick up the tools. Price points will vary from area to area depending on the region and it's permit processes. San Francisco will be different then rural Montana.
Ron
The Following User Says Thank You to Ron6519 For This Useful Post:
Old 02-06-2011, 01:16 PM   #10
Residential Designer
AndyGump's Avatar
Rewards Points: 684
Send a message via Skype™ to AndyGump
Are you saying that you're going out 16"?
If you tell me how far out the addition is and the pitch you want is, I can draw it real quick for you and give you a across section of what you need.
Joe, can I send you some plans and have you do them for free too?
Andy.
AndyGump is offline   Reply With Quote
Old 02-06-2011, 04:28 PM   #11
I was thinking of going 16' that way I wouldn't need to cut the flore joists the would run from the inside of a 2X12 ledger useing lv210 hangers conecting to the inside of my GLM with Lv210 hangers. The pitch of the roof has not been determind because I was not sure how I was going to tie in to the existing building. one though was to use cleats on the existing roof instead of the knee wall, although I was compleatly sure that was a very good idea. the existing roof is made with trusses not rafters.
Old 02-06-2011, 04:34 PM   #12
Framing Contractor
Here's a quick drawing of what you would do. It shows the kneewall if you need it and shows how you tie into the roof at the top. Will this addition be a cathedral ceiling? I drew it as one. If it is and you need the kneewall for sheetrock reasons and breaking the span of the long rafters need be.
Joe Carola
The Following 2 Users Say Thank You to Joe Carola For This Useful Post:
AndyGump (02-12-2011), wingchunbrother (02-06-2011)
Old 02-06-2011, 04:49 PM   #13
The drawing is what I was thinking for the most part, the drawing a friend of mine drew up for me did not have a knee wall just some cleats were you hve the plates. I realy don't care how much pitch the roof has as long as its up to code. the main thing I was thinking was to give the lowest point of the ceiling at least 8'. Not to say I don't need any pitch to my roof but I would be fine with more or less as long as its up to code. I do not have anyway to show you my plans or I would this is mostly just a storage room for lumber so I do need a strong floor and foundation.
Old 02-06-2011, 05:32 PM   #14
Framing Contractor
16' addition tying into the existing house where it intersects with the top of the truss with a small pitch will be some long rafters without a kneewall. Well, you have the idea with or without the kneewall. Whatever gets spec'd will do the job. You at least want to put a 4/12 pitch so that you have shingles instead of a flat roof.
Joe Carola
wingchunbrother (02-12-2011)
Old 02-12-2011, 09:44 AM   #15
I'd like to thank you for all your help, thank you for your time.
Jim
New construction on existing steel building burton Building & Construction 6 03-30-2010 03:22 PM
Building a room above existing extension Andy75 Building & Construction 2 02-26-2010 03:42 PM
Basement addition foundation questions hoggin03 Building & Construction 7 05-29-2009 07:28 AM
10 X 20 ft addition to existing house Dawn Smith Building & Construction 1 05-25-2009 07:31 PM
Addition to existing walk out alittleboutalot Building & Construction 1 12-17-2008 03:26 AM
