How To Add Support To A Wall - Building & Construction - DIY Chatroom Home Improvement Forum
Old 11-26-2012, 09:14 PM   #1
How to add support to a wall
I am in the process of mounting a 60" plasma above our fire place, I need to wall mount to be center of the fire place and mantel but the width of the mount is only 21" and there is a 2 x 4 dead center of the mantel. If I was to move the mount left or right so I could reach one of the other 2 x 4 it would make centering the TV on the wall mount 6.5" off center 3"-4" is max according to the manufacture specs.
8" off the top mantel is the header which means I can secure the bottom of the mount on the header and then only get one bolt in the center wall stud. The TV weighs 73 lbs and according to manufacture specs the mount needs to hold 4 times that amount so 292 lbs which means drywall anchors will not do the trick on the upper section of the mount. The mount I am using is a down and out mount which will bring the TV out 16.5" from the wall and the bring it down 27" from the top position of the TV, this is why the TV needs to be centered on the wall mount so it has a smooth transition from top position and the down position.
I have posted some photos of the wall in question and where the wall studs are and where the best position for the wall mount will be.
I actually thought about tearing down some of the drywall to add some support and then fixing the drywall. option #2 what if I take (2) 34" 3/4" x 2" secure those to the 3 wall studs but cutting out the drywall so as to have the cross member then center and secure the wall mount to the new cross members. Granted they will be visible when the TV is in the down position but will be hidden from view in the up position. By inserting the cross member into the wall it help reduce the distance from the wall, or should I use thicker piece of lumber.
Stayathomedad is offline   Reply With Quote
Old 11-26-2012, 09:33 PM   #2
AHH, SPANS!!!
Rewards Points: 1,166
are you able to put up a piece of 3/4 inch plywood 36" long by whatever width you need it to be. mabe put a back band or something around the edges of the ply to dress it out some... mount the plywood over top of the drywall to the wall with heavy duty GRX screws driven into all studs in the vicinity and then mount the tv bracket with a shorter version of the same screws to the plywood. You can get 2'x4' pieces of plywood at the box stores
The only other option I'd consider is to take down drywall,add appropriate blocking,and put drywall back up.
hand drive is offline   Reply With Quote
Old 11-26-2012, 09:54 PM   #3
I guess that could work, put a frame around it and paint the plywood the same color as the wall.
How to add support to a wall-mikes-i-phone-11.26.2012-015.jpg   How to add support to a wall-mikes-i-phone-11.26.2012-018.jpg   How to add support to a wall-mikes-i-phone-11.26.2012-017.jpg
Support below non-bearing wall handyman923 Carpentry 2 02-25-2011 09:09 AM
Adding support to a wall, need to reroute waste pipe and more sdrzewic Building & Construction 2 08-23-2010 12:16 PM
Support wall problem kilbert Building & Construction 13 04-15-2010 08:46 AM
Advice on retaining wall replacement (pics inside) eastie Building & Construction 0 04-05-2010 10:32 AM
Temporary wall support question discojv Building & Construction 7 01-25-2009 07:23 PM
