Old 08-26-2008, 01:59 AM   #1
How to achieve this stucco texture? --pix inside...
Ive removed a few windows in my house and also installed some french doors.
Id like to match the original texture of the surrounding stucco in the openings i need to patch. It seems to have some fine aggregate added to it to give it texture. Its like really small round stones or really large grains of sand. in the pictures its the white texture.
what should i add to the stucco to match this texture? Where can i get it....? etc.
also the grey texture is "texture paint" applied in the 60's or 70's, id assume.
do they still sell something i can use to approximate the texture?
thanks in advance!
Jon
Kooter is offline   Reply With Quote
Old 08-26-2008, 06:27 AM   #2
Lic. Builder/GC/Remodeler
AtlanticWBConst.'s Avatar
Looks like a heavy popcorn spray-texture.
FWIW: That texture was done with a spray-machine.
- Build Well -
Old 08-26-2008, 07:24 AM   #3
Most of your pictures are Dash and are done with a spray rig. As AWBC said.
The one with the flat spots is knock down it can also be done useing a machine.
stuccoman is offline   Reply With Quote
Vinyl siding and stucco. PrairieStudent Building & Construction 4 08-29-2008 04:03 PM
Where stucco meets the window & door; caulking Longleaf Building & Construction 12 08-12-2008 05:46 PM
color streaks on new stucco homeowner in Minnesota Building & Construction 2 08-11-2008 08:07 PM
Whats the best way to remove orange peel wall texture? billyg Carpentry 2 01-30-2008 05:09 PM
several problems while texture painting ceilings and walls carrotguy Painting 2 05-25-2007 04:38 PM
