Old 10-10-2010, 07:12 AM   #1
Housewrap over interior basement insulation
Can housewrap be used to cover and hold in interior basement insulation? We have synthtic instulation between studded walls and would like to cover the insulation with Lowes housewrap.
gpellock is offline   Reply With Quote
Old 10-10-2010, 07:51 AM   #2
Chicago, IL
Michael Thomas's Avatar
Interesting question.
The major issue, I think, would be flammability. I GOGGLED around a bit an could not find a definitive answer:
"DuPont™ Tyvek® is combustible and should be protected from a flame and other high heat sources. If the temperature of DuPont™ Tyvek® reaches 750°F (400°C), it will burn and the fire may spread and fall away from the point of ignition. For more information call 1-800-44-TYVEK. DuPont™ Tyvek® carries a Class I or NFPA Class A fire rating for flame spread and smoke developed index as measured by ASTM E-84."
- http://www2.dupont.com/Tyvek_Weather...rchitects.html
I do know that Tyvek clothing is flammable, and not recommended for applications such as welding unless specially coated, and that special Tyvek is available for applications requiring lower flame spread.
Home Inspections, Infrared (Thermal Imaging) Leak Identification and Inspection Services, Roof, Attic, Building, Basement and Foundation Moisture Intrusion and Water Leak Inspections, Troubled Building Consultations - Serving Chicago and Suburbs
Michael Thomas is offline   Reply With Quote
Old 10-11-2010, 02:21 AM   #3
Why house wrap? If for an air barrier, the ADA (airtight drywall approach) is a very commonly used method, and would very likely be a superior solution.
Cape Cod Style House Attic/Crawl Space Insulation Help Danielg Insulation 24 05-21-2012 09:20 AM
Question regarding Housewrap and Foam board insulation psychomti Building & Construction 16 10-27-2010 09:50 PM
How To Install Rigid Foam Insulation on Concrete earthad1 Building & Construction 9 10-26-2010 10:49 AM
How hard to install insulation yourself? techprincesse Building & Construction 26 10-17-2009 10:57 AM
Installing new insulation in my basement and removing the old moldy insulation. Fixitgeorge Remodeling 3 10-17-2006 09:33 PM
