Housewrap - Necessary? - Building & Construction - DIY Chatroom Home Improvement Forum
Old 08-17-2011, 09:05 AM   #1
Rewards Points: 28
housewrap - necessary?
I have a gable-roof shop that is frame-built atop a poured foundation. The walls studs are 2' apart. I have some water/dry rot on one gable end along the garage door header. There was not a good caulk seal and water got under the trim board and rotted the siding, sheathing, outside header, inner osb "sandwich" -- the inside header seems to be ok).
Sorry for the long story, but I noticed there is NO wrap on the gable end. This was built in 2005. I'm in NE KS. I don't know if this is common practice or what, but seems like in our wet, humid climate, wrap would be a good idea.
Thoughts?
coloradotrout is offline   Reply With Quote
Old 08-17-2011, 11:30 AM   #2
Rewards Points: 3,130
I'd put on some house wrap. It's not terribly expensive. Depending on your local codes, it may not be required for sheds and other outbuildings.
Old 08-17-2011, 05:14 PM   #3
Tom Struble's Avatar
Rewards Points: 2,002
a caulk seal will never work,get a metal drip cap over the trim
Tom Struble is offline   Reply With Quote
Old 08-17-2011, 05:20 PM   #4
kwikfishron's Avatar
Rewards Points: 344
Wrap is mandatory imo. If anyone tells you otherwise, fire them.
kwikfishron is online now   Reply With Quote
Old 08-17-2011, 06:56 PM   #5
Registered User
Rewards Points: 5,460
All these siding types require a water-resistive barrier; http://publicecodes.citation.com/ico...003_par006.htm
UNLESS you meet the “Exceptions” listed, as post #2 touched on; http://publicecodes.citation.com/ico...003_par003.htm
It’s pretty cheap not to include any when building……. my 2 cents.
Gary
The Following User Says Thank You to Gary in WA For This Useful Post:
AGWhitehouse (08-19-2011)
Old 08-18-2011, 08:20 PM   #6
Button Caps
If you do decide to put up housewrap make sure you use caps. Don't just staple or nail it on. Tyvek brand actually requires the use of caps or they won't warranty their product.
abitawheat is offline   Reply With Quote
The Following User Says Thank You to abitawheat For This Useful Post:
Tom Struble (08-18-2011)
Old 08-18-2011, 09:43 PM   #7
Rewards Points: 1,092
perhaps more important, or as much, is a rain screen. vertical 1x4's over the
'Tyvek", then siding, for ex. 30 lb felt is a great wrb, too.
Old 08-19-2011, 11:09 AM   #8
I've seen a lot of housewrap on both homes and commecial buildings. I have never, not even once, seen it put on with caps. Not Tyvek or any other brand.
Old 08-19-2011, 12:21 PM   #9
AGWhitehouse's Avatar
Actually just did some investigating into tyvek "housewrap" and they permit the use of 1" crown staples as an approved fastening method. All of their commercial products require capped fasteners.
See Page 4, Step 3, 4th fastener type.
http://www2.dupont.com/Tyvek_Weather...WRB_K16282.pdf
Life's too short...so enjoy it!
AGWhitehouse is offline   Reply With Quote
Old 08-19-2011, 12:23 PM   #10
The furring strips aren't allowed under vinyl siding. It requires a continuous substrate.
Old 08-19-2011, 11:04 PM   #11
this is what you want to use
housewrap - necessary?-0804111501.jpg   housewrap - necessary?-0804111502a.jpg   housewrap - necessary?-0804111505.jpg
Old 08-20-2011, 12:01 AM   #12
My bad warranty doesn't require but it's much better than just a staple. Moisture barrier stuff is a big deal.
Old 08-20-2011, 12:51 AM   #13
OK. Did not know. Is the "krinkle-wrap" stuff permitted?
Old 08-20-2011, 11:15 AM   #14
Registered User
Not to worry, JK, as you never mentioned vinyl with a rainscreen- or the OP (water got under the trim board and rotted the siding,). Never seen vinyl siding rot from water.......
It appears a WRB isn't required in an outbuilding (shop) in KC? As you said "water behind the trim"--- as Tom Struble pointed out you need metal pan flashing over horizontal trim, not caulk alone.
Hardie lap boards don't need a WRB unless local codes require it, though I can't see it water damaged... hence a picture is needed, rather than guessing the siding type and trim placement.
Gary
Old 08-20-2011, 01:17 PM   #15
yes it is,enhanced drainage is always a good idea but imo not really necessary with non foam adhered vinyl siding,i would recomend it on foam backed products
posting housewrap amakarevic Building & Construction 4 01-29-2011 07:48 PM
Question regarding Housewrap and Foam board insulation psychomti Building & Construction 16 10-27-2010 08:50 PM
housewrap amdhp Remodeling 8 10-20-2010 09:43 PM
Housewrap over interior basement insulation gpellock Building & Construction 2 10-11-2010 01:21 AM
tyvek housewrap in the ceiling rodeo Building & Construction 6 02-06-2008 11:21 AM
