-   -   Housewrap/Drainage Plane Behind Fiberfaced Polyiso or in Front? (http://www.diychatroom.com/f19/housewrap-drainage-plane-behind-fiberfaced-polyiso-front-107704/)
cloves 06-14-2011 09:32 PM
Hi everyone,
I am about to begin residing my house. I was wondering what everyone's input was on where the housewrap should go in this case. I had a previous topic with some great feedback located here (http://www.diychatroom.com/f19/polyi...46/) Which touched on a few related questions. :thumbsup:
House is located in North NJ (zone 5-6 border).
Materials:
-Framing is 2x4
-Fiberglass Batt Insulation R-13
-Polyiso 1.5" (fiberglass faced polyisocyanurate)(permeability <1.0) less than 1.0 according to the buildingscience article.
Design & Construction Option 1:
-Vinyl Siding
-Polyiso 1.5" (permeability <1.0)
-Housewrap (Tyvek or Dow)(Drainage Plane)
-1/2" Plywood
-2x4 Studs (Fiberglass Batt Insulation R13)
Design & Construction Option 2:
-Vinyl Siding
-1/2" Plywood
I am still a bit unsure of where the housewrap/drainage plane should be in my particular situation. Thoughts/comments?
kwikfishron 06-14-2011 09:44 PM
199 Attachment(s)
I prefer option 2 but instead of Tyvek (or the like) I’d use #30 felt.
cloves 06-15-2011 12:12 AM
Thanks for the reply kwikfishron,
I think #30 felt would def present breathability issues. My house is currently wrapped with #15, and in certain spots where I have pulled off the wood shingles, so I could reflash windows, I have seen spots where the water has hard time drying out after rainfalls.
cloves 06-20-2011 08:55 PM
Bump :)
Gary in WA 06-22-2011 10:08 PM
Read this and click on the yellow colored links: http://www.greenbuildingadvisor.com/...s-housewrap-go
Follow advice here on windows and doors: http://docs.google.com/viewer?a=v&q=...WrZBbBZoIUXgxw
And most of this: http://www.mtcc1170.com/images/BCRainScreen.pdf
Two layers even with vinyl: http://www.fortifiber.com/pdf/News_I...o%20Layers.pdf
http://www.energy.wsu.edu/ftp-ep/pub...importance.pdf
Fasteners leaks: http://www.google.com/url?sa=t&sourc...kv-Xgg&cad=rja
Other thoughts: http://docs.google.com/viewer?a=v&q=...4EyM707m0gPdXQ
Flash windows on foam: http://apps1.eere.energy.gov/buildin...rica/37583.pdf
The felt paper is better than housewrap under cedar that leaks tannins. Only better install would have been a rain-screen under the shingles: http://www.coastalcontractor.net/article/135.html
You are using plywood sheathing, not Zip system or OSB......
Tyvek, not Typar........
More on the polyiso, next time....
Gary
cloves 06-29-2011 12:51 AM
GBR thanks I will read up all the links you posted and post back! Thanks!
