House Wrapping - Building & Construction - DIY Chatroom Home Improvement Forum
Old 08-02-2009, 07:47 PM   #1
house wrapping
in the process of building a new house and trying to figure what i want to wrap it with. im thinking of using 3/8 fan fold, i think its about r1.8. is it worth using? and if so what sould i tpe the seems with? trying to stay away from foam board(rmax), very expensive. any advise appreciated.
roadhouse is offline   Reply With Quote
Old 08-03-2009, 06:06 AM   #2
If it is open cell foam(that lets moisture thru), it is probably OK. Every bit helps. But closed cell foam will trap moisture inside the wall cavity, not good. Tyvek is still probably the best housewrap. It lets moisture pass out but not in. It also depends on where you are located. Insulation and moisture barrier requirements vary depending on climate.
Old 08-03-2009, 08:54 PM   #3
imnot sure if its open cell or not. where i live its below zero in the winter and low 90s in the summer. im looking for more of a wind block with a little bit of insulation value.
Connecting main house to guest house... hlavine Building & Construction 31 03-28-2012 09:04 AM
replumbing an old house simonfrog Plumbing 7 01-30-2012 04:45 AM
Trane XR12 1.5 ton-Too small for my house? Badfish740 HVAC 7 09-23-2009 05:48 AM
I have Central Heating & Air, but house won't cool down..HELP!! exiledone1 HVAC 13 07-10-2009 10:09 PM
Brick and block house footer question. ourzoo Building & Construction 2 07-01-2006 02:57 PM
