House Wrap Question - Building & Construction - DIY Chatroom Home Improvement Forum
Old 06-11-2013, 09:44 AM   #1
house wrap question
When you have exterior rigid foam in addition to the sheathing should you apply the house wrap before the rigid foam directly to the sheathing or over the rigid foam? My thinking is the house wrap needs to be the last line of defense against any possible water getting in so I would fasten directly to sheathing. But if you do that you should integrate the house wrap with the flashing, therefore, the window would have to go in before the rigid foam, correct?
markharmon is offline   Reply With Quote
Old 06-11-2013, 11:40 AM   #2
Maryland
Just my opinion... but it should be sheathing, WRB and then foam. You can use something like Tyvek drainwrap for your WRB which would allow any trapped water to escape from behind the foam. As far as windows, why not just flash conventionally, install your window and then install padding/furring the same thickness as the foam around the window openings? The foam would butt to the padding/furring.
Pittsville is offline   Reply With Quote
Old 06-11-2013, 04:20 PM   #3
You mean install the window before or after the foam?
Old 06-12-2013, 07:19 AM   #4
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 4,718
More details needed on the windows. Are you doing them at the same time?
You can do it either way but if I were going to guess, most situations dictate that we wrap the sheathing first as Pittsville as well.
Old 06-12-2013, 12:29 PM   #5
Sheathing wrapped yes then rigid foam then install the new const. window or install foam after window is installed?
Old 06-12-2013, 02:44 PM   #6
Window outside the foam is easiest and more straightforward.
That being said, I prefer the housewrap over the foam and over the flashing of the window.
Old 06-12-2013, 02:58 PM   #7
kwikfishron's Avatar
Rewards Points: 598
Personally I don't like installing a flange window over foam. I'll pack out the framing the thickness of the foam, bring the foam up to that then flashing/housewrap.
kwikfishron is online now   Reply With Quote
Old 06-12-2013, 03:35 PM   #8
journeyman carpenter
woodworkbykirk's Avatar
Rewards Points: 1,214
kwik, if you do it that way you lose the thermal break at all your rough openings.. as for window first then foam. NO!! youll then have to install trim aroiund all the windows in order to have something for the siding to die into
woodworkbykirk is offline   Reply With Quote
Old 06-13-2013, 07:51 AM   #9
We don't like fastening to foam either but we make a sip panel around that opening to bring it level with the foam and still get the thermal break.
+1
Makes the trim details much more of a PITA and I just had to finally argue with a client and get them to go with an outie window locate.
House on Crawl Space - Sagging Center Beam - Need Advise stevenrossi Building & Construction 9 01-17-2017 10:32 AM
3/4" Styrofoam & House wrap Bubbles17 Insulation 7 03-16-2013 10:21 PM
House wrap after windows and doors? claxton Building & Construction 2 12-10-2011 09:10 PM
newby question regarding re-wiring house... dakotajoe Electrical 9 06-27-2011 10:04 PM
Patio roof to house attachment question mikemobile Building & Construction 1 09-30-2008 07:51 AM
