House Wrap On Inside Out - What To Do? - Building & Construction - DIY Chatroom Home Improvement Forum
Old 08-12-2008, 09:52 PM   #1
Knucklez's Avatar
Rewards Points: 930
house wrap on inside out - what to do?
i had a "duh" moment.. i put some Typar housewrap on backwards, i.e., with the grey fiber mesh facing out and the white side with logos facing the house.
i have already strapped that section of the wall so i don't really want to redo it..
does it make a difference its on backwards?
can i just go over top the housewrap (and strapping) with more housewrap, but facing the right way ?
thanks!
Knucklez
Knucklez is offline   Reply With Quote
Old 08-12-2008, 09:57 PM   #2
BUILDER / REMODELING CONT
buletbob's Avatar
thanks!
Knucklez
I'm not sure on the typar products, I only use tyvek and felt paper. if your going to go over it, then remove it and re do it this way you'll know its right.
Old 08-12-2008, 10:10 PM   #3
Knucklez's Avatar
Rewards Points: 930
thanks for the quick reply.
but i have already strapped the wall and didn't want to redo it if i don't have to. so that's what i'm trying to find out.
Old 08-12-2008, 10:11 PM   #4
Knucklez's Avatar
Rewards Points: 930
hmm.. maybe not a big problem
typar website says this:
Q. A builder client of ours has installed Typar backwards at a rim joist location. Should this be of concern?
A. Typar HouseWrap has a special UV coating on the light side that protects it from sunrays. If it is possible to replace it with the correct (the light) side out you will be assured that the product performance is at its maximum. Also, incorrect installation may void your warranty.
Old 08-12-2008, 10:13 PM   #5
buletbob's Avatar
I would not install it over the strapping you will build up moisture between the strapping and the second layer of house wrap.
Old 08-19-2008, 09:10 PM   #6
Knucklez's Avatar
Rewards Points: 930
what was i thinking.. no, i took it down and did it again right. that's what a DIY'er should do, take the time to do it right, no short cuts.
i almost fell for the being lazy trap.. thanks for the motivation to do it proper
Old 08-19-2008, 11:07 PM   #7
buletbob's Avatar
ANY time your starting a project and unsure about something. just post your questions here before you proceed , and you will be a happy camper! BOB
replumbing an old house simonfrog Plumbing 7 01-30-2012 05:45 AM
wall sheathing, foam board, insulation and house wrap dr.demento Building & Construction 10 10-18-2007 05:42 PM
Complete AC installation in Old Capitol Hill Row House jacko10 HVAC 0 09-18-2007 06:42 PM
Sealing exterior wall from inside the house? BigJimmy Building & Construction 6 03-20-2007 10:16 PM
house wrap? Neil_K Building & Construction 3 12-22-2004 10:14 PM
