House Wrap - Building & Construction - DIY Chatroom Home Improvement Forum
Old 03-09-2011, 04:10 PM   #1
house wrap
Can you put anything else beside siding over house wrap like plywood
mluns is offline   Reply With Quote
Old 03-10-2011, 02:02 AM   #2
Rewards Points: 1,092
Do you mean "plywood over Tyvek (for ex)"? The house wrap (water resistant barrier) won't be doing what it is designed to do if it is under plywood. If you are looking for air tightness, goo and tape the plywood, then put the WRB over that. Make sure the goo is compatible w/ the house wrap, and won't damage it. People often add 1x furring strips, along studs, and put siding over that. That gives a drainage plane if water gets behind the siding.
Old 03-10-2011, 05:51 PM   #3
Registered User
Rewards Points: 4,936
You can have structural siding over a housewrap; http://www.apawood.org/level_b.cfm?content=prd_sid_main
And, welcome to the forum!
Gary
Old 03-11-2011, 03:38 AM   #4
why do you want to?
shark722 is offline   Reply With Quote
House wrap over insulating foam board or under?? getn2old Building & Construction 7 07-28-2010 11:53 PM
installing whole house filter on outside of house MikeInFL Plumbing 3 06-12-2010 05:47 PM
Moving a House 70 miles- Practical? GOTHICrevivalRULES Building & Construction 19 11-27-2008 09:58 PM
house wrap on inside out - what to do? Knucklez Building & Construction 6 08-19-2008 11:07 PM
house wrap? Neil_K Building & Construction 3 12-22-2004 10:14 PM
