House Wrap? - Building & Construction - DIY Chatroom Home Improvement Forum
Old 12-10-2004, 02:13 PM   #1
house wrap?
Alright, footings are in, floor joists are in and the framing for my workshop will go up this weekend or next weekend (weather and time permitting). I know I'll have to work quickly once the framing is in to protect the untreated lumber from the weather.
My question today - what about wraps? The plans that I have called for basically construction paper. I was originally looking at something like Tyvek, but I wonder if its overkill, plus expensive. The guys at Lowe's said that plastic will work (I can't remember if he said 2mil or 4mil).
One bit of information that may affect responses - I will be using 7/16" OSB sheathing (Yeah, I know) and will be using hardiplank siding.
Thanks.
Neil
Neil_K is offline   Reply With Quote
Old 12-17-2004, 10:24 PM   #2
:confused:
Old 12-22-2004, 05:04 PM   #3
Grumpy's Avatar
Rewards Points: 552
Send a message via AIM to Grumpy Send a message via MSN to Grumpy Send a message via Yahoo to Grumpy
Tyvek is good. There are quite a few similiar products like Typar. Usually the framer puts these on.
Plastic will not work. Plastic is not a vapor barrier. Tyvek/Typar is a one way breathable vapor barrier. That means it lets moisture out but not in. If you put up plastic you WILL have constant humidity problems and probably mold.
The guys at lowes LOL. Not laughing at you... laughing at them.
-Grumpy http://www.illinoisroofinspections.com
The information found in this post is not to be considered legal advice. The author of this post takes no responsibility for any losses that occur. Use at your own risk.
Grumpy is offline   Reply With Quote
Old 12-22-2004, 09:14 PM   #4
Thanks, I'll go for the good stuff and use that roll of plastic for something else (like covering my wood when it rains). I wasn't sure since its supposed to be for a shed/workshop, but it may get insulated and lived in. :-)
Cape Cod Style House Attic/Crawl Space Insulation Help Danielg Insulation 24 05-21-2012 08:20 AM
replumbing an old house simonfrog Plumbing 7 01-30-2012 04:45 AM
House wrap. Clutchcargo Building & Construction 4 07-15-2007 03:33 PM
Re-siding house jdig Building & Construction 5 04-10-2007 09:15 AM
Partial House Wrap Bill46 Building & Construction 7 01-23-2006 03:41 PM
