House Siding For Modern Look - Building & Construction - DIY Chatroom Home Improvement Forum
Old 04-12-2008, 04:01 PM   #1
House siding for modern look
My 1965 house has wood panel siding (applied in sheets) and now needs to be replaced. Does this have to be done by a contractor? Are the wood and concrete mix siding panels I've heard of good? My house is modern looking, and I don't want a cottage feel. Any siding recommendations other than a smooth plaster? And, it's on stilts, so no heavy concrete anything. Thanks!
Olive is offline   Reply With Quote
Old 05-07-2008, 07:48 AM   #2
I have gas!
Clutchcargo's Avatar
Rewards Points: 1,312
Hardie has a fiber cement vertical siding product that you may be looking for. A contractor would have all the tools and expertise to install it properly. If you're an adventurous DIYer, you could DIY as well but you will need to get the correct cutting tools.
I tear things down and build them up.
Clutchcargo is offline   Reply With Quote
Complete AC installation in Old Capitol Hill Row House jacko10 HVAC 0 09-18-2007 06:42 PM
Replacing Wood Panel 4'x8' Siding Chevmann99 General DIY Discussions 5 10-02-2005 08:43 PM
Siding: Aluminum vs. Vinyl Grumpy Remodeling 1 03-19-2005 01:55 PM
Siding: Aluminum vs. Vinyl Grumpy Remodeling 0 04-18-2004 04:35 PM
