House Settling Issues - Part 2 - Building & Construction - DIY Chatroom Home Improvement Forum
Old 02-20-2011, 02:06 PM   #1
Still Learning DIY'er
House settling issues - part 2
Hello Experts,
Another issue that possibly shimming a couple other pillars would fix is the gap between the front rooms wood laminate flooring and tile flooring of kitchen. This was a 1/8in gap to begin with all along the 148 edge. Now it is 1/4in wide at outside wall and widens to 3/8in roughly 4- 8 in and then tapers back down to 1/8in at inside wall.
I have wondered if the tile flooring was put down correctly, as the tiles height is above the wood floor. It definitely hurts to walk barefooted and step on the Aluminum Square Edge Trim
Another issue that may be the wood laminate flooring or substructure is that the floor seems wavy when compared to the baseboard. Every few feet it dips. I placed a level and it shows about a 1/8in drop at the low points down the wall.
If you have any suggestions or thoughts as to what I can do to fix these issues or if you need any other information, please let me know...
Thanks in Advance,
Gary
gmvshort is offline   Reply With Quote
House settling issues gmvshort Building & Construction 3 02-22-2011 06:26 AM
Is my house going to fall down...or it just settling? bleecker Building & Construction 6 09-20-2010 12:27 PM
installing whole house filter on outside of house MikeInFL Plumbing 3 06-12-2010 04:47 PM
Trane XR12 1.5 ton-Too small for my house? Badfish740 HVAC 7 09-23-2009 05:48 AM
Need to Jack up part of my house.... harleysilo Remodeling 24 10-01-2006 08:05 AM
