House Out Of Plumb - Building & Construction - DIY Chatroom Home Improvement Forum
Old 09-12-2011, 08:41 PM   #1
Rewards Points: 6,652
House out of plumb
Just sat down at my son's desk, and I was wondering why it looks like it is leaning towards the back. Used the level app on my iPhone, and it shows the house to be -0.7 out of plumb. I knew that our house was dropping on one side, but did not realize it was that much.
Old 09-13-2011, 05:37 AM   #2
DIY staff
Rewards Points: 7,174
That is what you get for having a level built into your phone!
Use a match book under the legs of the desk.
Old 09-13-2011, 06:27 AM   #3
I would stop wasting money on phone apps and hire an engineer to find out what is wrong with house.
Few houses are absolutely level or plumb, although they are usually very close. Not sure what -0.7 means???????? If yours is out far enough to be visual, you need to find out why.
Old 09-13-2011, 07:06 AM   #4
so, about 3/4 of an inch...does it translate across the entire house, or just the room the desk is in? My old house is out of plumb in several different directions. It gives me fits when installing anything which needs to be true, but its also part of the character.
1910NE is offline   Reply With Quote
Old 09-13-2011, 09:10 AM   #5
Actually it is that corner of the house. When we moved in eight years ago, you could tell that corner had settled. Just looking at the doors on that side, it shows. And the app actually was free. I just have to get that side jacked back up is all, so it is plumb.
Old 09-13-2011, 11:10 AM   #6
I ask the impossible!
Rewards Points: 692
0.7 degrees means that you have 1.173" of being off of vertical over an 8' distance.
Please do NOT consider any "before" picture of my house as any kind of endorsement of any particular construction method. In fact, you should probably assume that if I post a "before" picture, I am posting it because I am soliciting advice on a proper replacement for one of MANY things done wrong by a previous owner.
WillK is offline   Reply With Quote
Old 09-13-2011, 11:32 AM   #7
That is what I am thinking. I was getting the same reading off of the floor. I have a four foot bubble level, but I may get a digital level to see, before I replace the lally column downstairs. You can tell by looking at the block and the sill plate, how much that side under the bedroom in that corner has sunk. I think that a lot had to do with the previous owner not making sure that the gutters were extended far enough.
When we moved in, we had to put extenders on the downspouts, due to the one on the North West corner was actually causing water to get down along the foundation and when I caught it, it was seeping through the foundation aprx 2 1/2 feet up. Since I fixed the downspout issue, no more problem with rainwater causing problems.
My house's previous owner - DIY horror stories Leah Frances General DIY Discussions 153 01-21-2016 07:18 PM
My house progress so far - over the years Snav Project Showcase 5 05-06-2015 11:11 AM
Cape Cod Style House Attic/Crawl Space Insulation Help Danielg Insulation 24 05-21-2012 08:20 AM
replumbing an old house simonfrog Plumbing 7 01-30-2012 04:45 AM
I have Central Heating & Air, but house won't cool down..HELP!! exiledone1 HVAC 13 07-10-2009 10:09 PM
