Old 12-31-2009, 02:40 AM   #1
House has 2 Slabs in It
I Just bought another House and I was ripping up the Carpet and Found that the Concrete Slab was Very rough and that the wall plates where in the concrete so Hammered out part of the slab and found that the slab was only 1.5 inch thick and then Polly and then I found another Slab - I hammered in that one and found it was 4" Thick - I assume That the owner before me was having moisture problems in the basment. Should I remove this slab. There is little Water droplets under the polly - what should I do? Looks Like this slab was poured all around the walls?
EV-Dutchy is offline   Reply With Quote
Old 12-31-2009, 03:06 AM   #2
Tool Geek
PaliBob's Avatar
Ev, Welcome to the Forum
Are you referring to a below grade concrete slab in the basement?
You may have a legal issue here.
What is your location?
& Stay Safe
.....Bob Lavery
Old 01-01-2010, 01:27 PM   #3
Yes I referring to my 4ft below grade Basement -
I live in Canada in BC
Tags
basement, concrete, moisture, slab
Connecting main house to guest house... hlavine Building & Construction 31 03-28-2012 10:04 AM
replumbing an old house simonfrog Plumbing 7 01-30-2012 05:45 AM
Trane XR12 1.5 ton-Too small for my house? Badfish740 HVAC 7 09-23-2009 06:48 AM
I have Central Heating & Air, but house won't cool down..HELP!! exiledone1 HVAC 13 07-10-2009 11:09 PM
Brick and block house footer question. ourzoo Building & Construction 2 07-01-2006 03:57 PM
