House Flipping Permit Questions Wisconsin - Building & Construction - DIY Chatroom Home Improvement Forum
Old 02-13-2011, 04:40 PM   #1
I am wondering what I can pull permits for as a homeowner, but not an occupant of a house. I purchased a house to gut, remodel and flip. I am trying to find a site with rules and regs about what I can do without a contractor license. I am going to pull permits but I want to know what I can do without hiring someone else. Thanks for your help. I am in Wisconsin.
SparkandArc is offline   Reply With Quote
Old 02-13-2011, 06:42 PM   #2
Experienced
Jackofall1's Avatar
Welcome Spark, to the best DIY"r site on the web.
I would suggest calling your local building department for the answer to that question. Most area's allow home owners to do all there own work as long as it follows the appropriate codes for the area you are in.
You can also search the web for local codes in your area.
Mark
Old 02-13-2011, 06:46 PM   #3
Licensed P.E./Home Insp
Aggie67's Avatar
Rewards Points: 808
Call your local building department and pose the same exact question. Rules vary from town to town on what they require for owner-occupied and not occupied property. I can tell you that my guess is that the electrical and plumbing will probably have to be done by licensed contractors.
Aggie67 is offline   Reply With Quote
Old 02-13-2011, 06:58 PM   #4
Most jurisdictions will allow a homeowner to pull permits for any work being done to their own home but it must be their primary residence. You have to ask the building dept. at each jurisdiction. Be up-front with them because many inspectors will void the permits if they discover that the dwelling is a flip or rental and you won't get your money back.
Tigerloose is offline   Reply With Quote
Cape Cod Style House Attic/Crawl Space Insulation Help Danielg Insulation 24 05-21-2012 09:20 AM
installing whole house filter on outside of house MikeInFL Plumbing 3 06-12-2010 05:47 PM
Aluminum-wired house, questions LMH Electrical 2 05-24-2009 04:06 AM
Unfused connectors MELTED House wires WHAT TO DO??? jamiedolan Electrical 63 02-12-2009 07:01 PM
Moving a House 70 miles- Practical? GOTHICrevivalRULES Building & Construction 19 11-27-2008 09:58 PM
