House With Extremely Low Ceilings - Building & Construction - DIY Chatroom Home Improvement Forum
Old 03-10-2011, 12:26 PM   #1
My Fiance and I found this house. It's a foreclosure. And the price is very low. Roof is solid, house is solid. Unfortunately the ceilings are 6 foot MAX. Doorways are less, on the bottom floor. The upstairs is higher, I'd say about average. My question is... If we got this, and gutted it. Is there a way to raise the the 2nd story floor effectively without weakening the structural integrity of the house itself. I'm talking gutting it completely and basically starting with a shell. Any input would be greatly appreciated! Thanks
redracer87 is offline   Reply With Quote
Old 03-10-2011, 12:37 PM   #2
Learning by Doing
Leah Frances's Avatar
Are the ceilings really 6 foot? Or have they been dropped to that level?
If I could only remember to THINK about what I was doing before I did it.
Leah Frances is offline   Reply With Quote
Old 03-10-2011, 12:40 PM   #3
The joists behind the drop ceiling is literally 6 foot. The doorways are even less. I'm 6'2 and it's impossible for me to stand up in any room on the bottom floor.
Old 03-10-2011, 12:51 PM   #4
Love for Construction
<*(((><'s Avatar
Is the bottom floor a basement?
If so you could always go down, there are subcontractors that specialize in putting full basements under existing houses, with new foundations.
-luke-
<*(((>< is offline   Reply With Quote
Old 03-10-2011, 12:52 PM   #5
The basement is a dirt floor crawl space.
Old 03-10-2011, 12:56 PM   #6
Learning by Doing
No offense intended. But why would you want to buy this house? Give us an idea of what you are up for and we'll help you guess what you are in for.
Old 03-10-2011, 12:57 PM   #7
Learning by Doing
Pictures or it didn't happen.
Old 03-10-2011, 01:04 PM   #8
No offense taken. Basically this house is dirt cheap. And reasonably so. But we LOVE the area. It's got a massive garage that would be perfect for my tractors, etc... That is why we love it. It's got a beautiful little patio area, a fenced in yard... It's everything we want, from the outside. My main question is would this be a lost cause? Or is it worth while? And what exactly IS possible as far as fixing this? I have no problem gutting the entire house. But is it possible to relocate floor joists for the 2nd floor, to be higher. I'm not a construction expert or else I wouldn't bother you guys. It's just a make or break on this house... My uncle is a contractor and builds houses for a living, but I wanted to get some opinions before I bother him. If that makes any sense.
Old 03-10-2011, 03:14 PM   #9
Master General ReEngineer
Bondo's Avatar
Rewards Points: 1,628
Ayuh,... ANYTHING is Possible,.... Practical is another matter...
Your questions really can't be answered without knowing/ seeing the type of construction, as well as many other factors involved...
There's a rather High possibility that just Crushin' the house, 'n startin' over could be Much more practical, 'n Cheaper...
Whether it's Worth While or not?? is up to You, 'n yer Love...
Bondo is online now   Reply With Quote
Old 03-10-2011, 03:42 PM   #10
FlyingHammer
Rather than trying to raise the floor joists on the 2nd floor, why not just jack up the whole house and install a new 1st floor? Seems like it would be a lot easier. That said, it really sounds like you'd be better off bulldozing and starting over.
FlyingHammer is offline   Reply With Quote
Old 03-10-2011, 04:00 PM   #11
Rewards Points: 120
There will be plenty of opportunities, I am sure, to seek and receive valuable advice here, but given the amount of time that you will spend writing posts, posting pictures, etc., and others will spend trying to guide you through a thorough assesment of this particular house, I would strongly encourage you, since you have that option available, to ask your uncle to take a look at it. In fairly short order, he should be able to determine whether it is conventional framing or balloon framing, whether there are false ceilings throughout the first floor, etc. It is great that you don't want to constantly bother him with such matters, but since it sounds like the location and property are what you want, I would make that call. If not, my next suggestion is to start posting some pictures here, and see where that takes you. I would start with the outside form a couple of differnt angles, and as much framing as you can see inside. You should also measure the thickness of the first floor ceiling, which you should be able to approximate pretty close in the area of the stairs, as that may reveal the possiblity of a false ceiling, in which case you will need to start asking the "why" questions.
Old 03-11-2011, 07:45 AM   #12
Through talking to several different contractors... It pretty much breaks down like this...
Cost wise, to gut it, fix it (several different ways), and make it liveable again... Materials would be much much cheaper than building a new house, getting a modular, etc...
To pay for the time to pay a contractor... It'd be more cost effective, and I feel more logical, to start from scratch with building a new home, or modular... whatever the case may be.
Thank you all.
Old 03-11-2011, 09:55 AM   #13
rditz's Avatar
I agree with Dexter.. If you have an opportunity to speak to someone you trust (Uncle), then why wouldn't you consult him so that you get the real situation... that is, unless you are afraid to hear that it might NOT be worth it..
"Worth" is a matter of opinion. and the opinion that matters the most is yours. If you think it is worth it, then I say Go for it...
your uncle will also be able to tell you the best way to get the ceiling height to be more comfortable...
good luck
rod
rditz is offline   Reply With Quote
Old 03-11-2011, 11:13 AM   #14
Learning by Doing
Thank you all.
Your first realty crush is always hard. Rent the Money Pit and watch it with your fiance. Then re-asses.
Weird wiring in house fdmillion Electrical 13 06-14-2013 06:49 PM
replumbing an old house simonfrog Plumbing 7 01-30-2012 04:45 AM
Questions about jacking up house to replace rotted rim/sill SolidStateS15 Remodeling 10 03-22-2010 11:43 AM
Patio roof to house attachment question mikemobile Building & Construction 1 09-30-2008 07:51 AM
help me solve this mystery please lindaberrien Roofing/Siding 17 06-12-2007 01:06 AM
