Hot Vent Pipe Insulation - Building & Construction - DIY Chatroom Home Improvement Forum
Old 12-07-2010, 05:57 PM   #1
hot vent pipe insulation
I have a tankless water heater that must vent through the roof. what/how do I insulate the hot vent pipe from drywall, insulation, etc. as it passes through the ceiling in route to roof?
4cedars is offline   Reply With Quote
Old 12-07-2010, 07:28 PM   #2
Rewards Points: 5,336
These units come with precise instructions as to their installation.
Was yours missing? If so, the company has a website where you can obtain a replacement.
Ron
Old 12-07-2010, 09:15 PM   #3
Tankless heat vent
The heater is installed per the directions. There was no insulation directions for passing through the insulated joists between the first floor and the roof. Is there a fireproof insulation that could be used?
Old 12-07-2010, 09:39 PM   #4
Post the make and model number.
Ron
Old 12-08-2010, 08:11 AM   #5
Tankless model #
It is a Takagi T-K2. I am using Z-Vent III from Z-Flex for the vent pipe. Thanks for your help.
Old 12-08-2010, 09:58 AM   #6
The Z-vent instructions for the pipe are online if they didn't come with the pipe.
I hope you know what you're doing with this. I'd install an interconnected CO alarm just in case.
Ron
Old 12-08-2010, 10:07 AM   #7
Hot vent pipe
Thanks Ron,
The heater was installed by licensed persons 6-7 years ago and has worked perfectly. A recent decision to modify the laundry room.....forced the insulation issues.
Old 12-08-2010, 10:26 AM   #8
Thanks Ron,
Then why can't you look at the current configuration and clearances and use that information?
Ron
Run vent pipe in soffit along with duct trunk acerunner Plumbing 1 09-28-2010 08:06 PM
steam pipe insulation ant1929 HVAC 2 02-02-2010 07:56 AM
Water dripping from vent pipe Rosy_55 Plumbing 4 01-07-2010 09:35 AM
iron vent pipe broken at fitting CCarlson Plumbing 3 02-18-2009 07:40 PM
framing conundrum: 2" PVC vent pipe going horizontal through 2x4 studs amakarevic Building & Construction 18 01-19-2008 06:47 PM
