Hot Tub Support Question - Building & Construction - DIY Chatroom Home Improvement Forum
Old 08-02-2012, 05:29 PM   #1
hot tub Support Question
I'm putting a hot tub on a separate deck that is 8'x5'6 on 4-12" round concrete pillars that are 42" deep. I have 2 sets of 2 2x12 beams with 2x10 joist &16" centers. The pillars are 7' apart and was told they should be 4' apart. Should I add some more pillars in the center? (total weight is about 1 2898lb.)
gco8888 is offline   Reply With Quote
Old 08-03-2012, 12:08 AM   #2
GBrackins's Avatar
Rewards Points: 2,108
how high above the ground will your deck be for the hot tub, and what is the weight of the hot tub with water?
Gary
"You get what you pay for, and sometimes free costs more!"
GBrackins is offline   Reply With Quote
Old 08-03-2012, 09:16 AM   #3
Civil Engineer
Rewards Points: 4,522
The total weight you posted must have a typo in it, try it again.
As to design, the prescriptive residential deck code does not cover spas on the deck, so the design of the deck framing is usually provided either by an engineer, the manufacturer of the spa, or by an experienced deck designer. The calculations normally are submitted to the building inspector when you pull your deck permit. I do not recommend using an internet chat forum for critical design issues such as framing for a heavy structure on a raised deck that falls outside standard code, I suggest you start by talking to your building inspector to see what they think.
Old 08-03-2012, 09:32 AM   #4
Max filled 2898lb
GCO88 is offline   Reply With Quote
Old 08-03-2012, 10:33 AM   #5
GBrackins's Avatar
how high off the ground
Gary
Best Method for attaching decking lateral support getzjd Building & Construction 2 05-19-2010 07:45 AM
Basement support post failure fetzer85 Building & Construction 15 05-09-2010 11:35 PM
moving a support wall 6 ft over.? help jstamps Building & Construction 1 04-20-2010 06:48 AM
Temporarily remove basement support post ColinD Building & Construction 14 12-04-2008 06:07 PM
need help on repairing rotted deck support ga1990 Building & Construction 6 11-07-2008 08:32 PM
