Hot Tub Room - Building & Construction - DIY Chatroom Home Improvement Forum
Old 02-08-2011, 12:22 PM   #1
hot tub room
I am getting reedy to build a 24 x 20 sun room which i plan to install a hot tub in it and was wandering what would be good to put on the walls. The room will not have heat in it
jmiller98 is offline   Reply With Quote
Old 02-08-2011, 11:19 PM   #2
cedar siding (lap joint)
proremodel is offline   Reply With Quote
Old 02-09-2011, 12:00 AM   #3
Registered User
Termite's Avatar
Yup, that would be a good product for that application.
Old 02-09-2011, 12:02 AM   #4
Also to have it really cool don't stain it or anything. Let it weather in there naturally. It will have a ton of color in it along with a little graying. Maybe finish it if you are leaving it half open to the elements.
Old 02-09-2011, 01:04 PM   #5
Rewards Points: 1,062
make sure you ask some structural engineer whether your house/building can support the weight of the tub
Old 02-09-2011, 01:09 PM   #6
Experienced
Jackofall1's Avatar
I would think that you should build the entire structure from cedar, to cope with the ultra high humidity that the tub will create.
Mark
Old 02-09-2011, 01:10 PM   #7
remodeling pro
There are many products with plastic, melamine, or embossed aluminum bonded to a sheet good, but I agree that cedar or redwood lap siding will provide the best ambience for such a room.
I'd use stainless nails so you don't end up with little black splotches everywhere in a couple of years.
Also would install a quality, commercial duty exhaust vent wired to a humidistat. There is going to be an awful lot of humidity/conndendation created in the room when the tub is uncovered and in use.
troubleseeker is offline   Reply With Quote
Insulating a cold/well room? Lynch Building & Construction 23 07-25-2014 02:49 PM
advice/Help on non-permitted bonus room? Orange_County General DIY Discussions 43 06-11-2010 05:06 PM
What Makes A Room A Bedroom? HowToGuy Remodeling 11 02-26-2010 02:44 PM
First Question: How to cool this room? Warhammer: 3025 HVAC 4 03-25-2009 10:02 AM
Room to Room Vent cjpilot HVAC 5 12-02-2007 08:53 PM
