Hot Tub Foundation - Building & Construction - DIY Chatroom Home Improvement Forum
Old 06-09-2011, 10:05 PM   #1
Hot Tub Foundation
Hello everyone!
I am getting a hot tub and am building a foundation for it. I need opinions to see if this will work.
I bought (4) 8' treated 2X4 and will use a total of 12 galvanized nails to make a box out of them to sit on top of the ground. Then, I am going to pour pea gravel inside the box (and make it level.) I am going to put treated plywood on top of the pea gravel and the hot tub will sit on top of that. Any reason for this not to work?
Thanks all!
mwahl2 is offline   Reply With Quote
Old 06-10-2011, 06:24 AM   #2
Rewards Points: 4,748
doesn't the tub manufacturer have support specs for your unit ? if it were me, i wouldn't bother w/the plywood & substitute compactible granular base ( any quarry ),,, pea stone shifts & can't be satisfactorily compacted,,, you've already considered existing soils condition/type & susceptibility to freeze/that, correct ? that's MY opinion
stadry is online now   Reply With Quote
Old 06-10-2011, 07:39 AM   #3
Not so new
12penny's Avatar
Rewards Points: 520
...yea...cant imagine pt plywood is going to last very long. Since you're making a frame for it any way, why not fill it with concrete?
12penny is offline   Reply With Quote
Old 06-10-2011, 07:53 AM   #4
Civil Engineer
Rewards Points: 4,856
The actual per square foot load of a hot tub is not that great, so it will generally work on decent soils with limited improvement. For example, a four foot deep hot tub exerts about 250 pounds per square foot. Compacted angular gravel or road base can support easily 2000 psf.
The key is to remove unacceptable soil first, before you place your support layer. Unacceptable soil would include organic soil, uncompacted fill, wood, debris, or other waste material, soft clay, and soft silt. Once you get down to decent mineral soil, meaning sand, gravel, hard clay, glacial till, or dense silt, you can backfill to grade with structural fill, compacting in six inch lifts as you go.
Of course, you can read the manufacturer's recommendations on base preparation, as previously suggested. You can also discuss foundation requirements with the building inspector, if a permit is required. I second the opinion to skip the plywood, it is unnecessary, and likely to rot over time. Similarly, if you feel you need a barrier for the fill, make sure the PT you use is rated for ground contact, most PT sold at the big box stores is NOT rated for ground contact.
Stone Foundation 'Temporary' Repair... Peter B. Building & Construction 17 12-16-2010 12:27 PM
moist soil under raised foundation during winter bn300 Building & Construction 0 09-17-2010 02:51 AM
Round House Foundation Feasibility Mswick Building & Construction 23 02-27-2010 08:34 AM
Foundation Repair Help rasilun Remodeling 1 10-15-2009 10:26 PM
How to add footing and foundation to existing foundation? ptcamaro Building & Construction 6 06-22-2009 10:22 AM
