Hot Air Ducts From Botton Of Main Trunk? - Building & Construction - DIY Chatroom Home Improvement Forum
Old 09-26-2010, 06:18 PM   #1
Hot air ducts from botton of main trunk?
I want to move two ceiling hot air ducts in my new house to near the base of the basement wall. It will be easy if I can tap into the botton of the main hot air trunk and go straight down between the studs of a 2 x 6" wall that I plan to build. Can I tap into the bottom of the main truck or should I tap in on the side or top?
bmoorethunder is offline   Reply With Quote
How to drywall wall with HVAC trunk and pipe penetrations daphilli Drywall & Plaster 3 09-27-2010 02:15 AM
Add Duct to Main Trunk naturalmystic HVAC 3 11-17-2009 02:25 PM
Help with gas pack trunk sizing justinNC HVAC 3 10-31-2009 08:38 PM
where to position the main trunk? drewhart HVAC 3 02-12-2009 02:16 PM
main lug vs main breaker for sub panel diyll Electrical 1 01-17-2008 08:18 PM
