-   -   homemade drywall lift (http://www.diychatroom.com/f19/homemade-drywall-lift-28959/)
DangerMouse 09-29-2008 10:57 AM
i'm creating a drywall lift from 2x, hinges and a crank-type chain fall or possibly rope and crank. anyone out there want to help? i have a rough pencil sketch in "My Photos" (to your left under my avatar)
DM
clasact 09-29-2008 01:02 PM
why not just go on ebay and buy one I just did got it for 124.00 and that was with shipping brand new in the box
DangerMouse 09-29-2008 01:05 PM
well sure.... if i had $124 laying around.... this can be made with what i already have.....
DM
clasact 09-29-2008 01:07 PM
I see said the blind man good luck
Maintenance 6 09-29-2008 01:41 PM
Any time a mouse wants to build a drywall lift, I'm ready to have a look :laughing:
DangerMouse 09-29-2008 02:44 PM
thanks M6, when it's built and tested and safe, i'll post pics and plans for all to see. maybe i'll send a copy to motherearthnews too, the homemade one they show has no plans, just a drawing and measurements. pretty confusing to the average person. i could still build theirs, but i think mine would be easier and cheaper to build. another i saw a drawing of was just a car jack setup.... looked hard to use and unsafe to me.
DM
DangerMouse 09-29-2008 04:24 PM
ok, i put the pics in My Photos. my problem is how to keep the top platform level as it rises. at this point it's more of a 2 man tool. one person to hold the sheet level as it's going up, then the ceiling will hold it flat as it's being positioned. if i get time today, i'll draw the thing with chainfall (or perhaps crank and pulley?) attached and in more detail. comments and serious suggestions welcome. and yes, i know it only shows one locking wheel, there will be 4, of course.
DM
DangerMouse 09-30-2008 06:35 AM
also, the top shows just one end being adjustable, both sides will bolt/wingnut securely to expand for larger sheets. this design is for ceiling only, not walls.
DM
RippySkippy 09-30-2008 09:01 AM
Originally Posted by clasact (Post 166351)
I see said the blind man.....
as he took out a hammer and saw....
DangerMouse 09-30-2008 09:18 AM
thanks for that rippy, your response was quite trippy. but what did he see? an idea to help me?
DM
4just1don 09-30-2008 01:57 PM
Downside "I" see to the 2 bye gizmo MIGHT be sheer weight. IF You have a work force of about 4 to carry it around,,,which brings up storage probs,,,wetness isnt woods friend. I am NOT blessed with abunduance of storage SO,,,I dont have one of neither,,altho I WISH I had!! Long story short,,,compute weight of total structure before assembling!!(and factor in the LEAST number of workers to MOVE it!!)
RippySkippy 09-30-2008 03:11 PM
DM
Nope can't help you...that was just the second half of the one liner my grandfather used to say when we would hang out...no insult intended...just triggered an old memory...
Termite 09-30-2008 03:34 PM
Wow mouse. Not sure I understand quite how this contraption works!
I do pretty well hanging by myself with a 2x4 "T" cut just a hair taller that the ceiling. It takes a lot of cussing but it works when all your friends are busy on sheetrock day. :yes:
Big Bob 09-30-2008 07:50 PM
D..Mouse, o'l bud,,
Drywall hanging and roofing are games for young folk.. (it's what helps make'em older an sore'er) If you are determined to DIY... and not help the guy on the street corner "will work for food".. (lots of new home construction hangers headed there now)...
Do you need to build a boat to cross a creek you can jump over?
How many thousands of SF do you need to hang?
How many real legs have you got? ( I once had a one armed painter on the crew... (No, I never asked him if he could hang wall paper).
One man hanging made a little easier....?:
If you are able... 2x4 deadman "T"'s as KCtermite advised plus you can make few arms... ( 2x4 blocks " long as you want them 3'-4' add fat "size of rock" spacer... nail to bottom of ceiling joist ...Position so you can slide
sheet in the slot.. hold other edge with one hand while you grab the deadman "T"
... go rest on the couch... when rested... adjust sheet to right spot... pull the deadman tight again... and screw away.... Repeat until you run out of ceiling.... Or if you are having fun... install another layer... be sure you cut the deadmans leg off the thickness of the rock.
Your design looks cool...and it just might fly.
Stay safe.
joasis 09-30-2008 08:05 PM
Give a little thought to my advice, and I am not saying you can't do it, but:
A decent drywall lift can be rented for $20, maybe $40. So what is your time worth and plus the ease of using a lift? I have done it with 2x's and a tee, and 2 guys and sweat, and I promise you, it is worth the bucks...and if you still can't think about the rent, then buy one, some are as low as $100, and sell it on craigslist when you finish.
