Home Extension Over Window Wells - Building & Construction - DIY Chatroom Home Improvement Forum
Old 02-04-2012, 05:10 PM   #1
My wife and I have been thinking of extending our home. we have a Rambler home with vaulted celings, and we're thinking of extending on the back side of the house from one side to the other anywhere from 7- 12 feet more, this would extend our kitchen and master bedroom, and would also add one more room to our house. however on the back of our house we have 2 window wells and this extension would cover those two window wells up. I know that we will have to have a means of egress for our basement living room. down stairs where these two windows are there is also one more window that is on the side of the house in this same family room. Has any one had any experience with this, or know of anything that would restrict us from doing this home extension?
instantbradley is offline   Reply With Quote
Old 02-04-2012, 05:18 PM   #2
Rewards Points: 14,306
Need to be talking to a local GC about all this.
There going to be able to be on site and see what your talking about, know local codes, soil conditions ect.
Old 02-04-2012, 11:26 PM   #3
robertcdf's Avatar
USUALLY and this is just a USUALLY, if the room is smaller than 500 SQ ft then the other window is sufficient as long as it meets all other egress requirements (size, clearances, height, etc). HOWEVER your local building department may feel differently so they are the only ones who can answer for certain.
robertcdf is offline   Reply With Quote
Old 02-10-2012, 02:08 PM   #4
Planning on removing the existing rear wall of the house?
Marvel is offline   Reply With Quote
Old 02-10-2012, 02:20 PM   #5
Yes that is the plan, to remove the back wall of the house (after the extension has been built. just wondering if anyone has any EXPERIENCE with this other than the cookie cutter answer that i need to talk to an engineer or building department about this. That's an obvious step in my process, but obviously i'm not to that step yet, i'm just batting around ideas with some fellow DIY-ers and trying to see if any one else has experience with this..
Old 02-10-2012, 02:28 PM   #6
If you have sufficient space on your lot I would investigate a different solution. What you are proposing isn't cost effective nor is attempting to remove the old exterior wall after.
Old 02-10-2012, 04:21 PM   #7
Residential Designer
AndyGump's Avatar
Rewards Points: 688
Send a message via Skype™ to AndyGump
As long as you provide a means of egress for the basement I don't see anything else in your description that would not allow you to do the addition.
Andy.
Residential Drafter/Designer
www.draftinginoc.com
AndyGump is offline   Reply With Quote
Old 02-10-2012, 07:19 PM   #8
robertcdf's Avatar
You were given the cookie cutter response because when it comes to EGRESS the only person who can make that determination is your local inspector. UNLESS someone else who lives in the same area, did the exact same addition in the last week AND had the exact same layout in their basement... AND that person was on here... Now what do you think the chances of that are?
If you don't want help then don't ask, you should be appreciative to those who answered your question otherwise next time you ask they won't bother responding.
Tags
home extension , means of egress
Lowes or Home Depot for window & door installation? wandie2me Windows and Doors 22 03-17-2012 03:54 AM
brick wall window -- replacement review amakarevic Building & Construction 3 01-24-2012 01:48 PM
Condensation on fiberglass window frame creamaster General DIY Discussions 11 01-05-2012 07:42 PM
Removing a window for painting... JJDoherty General DIY Discussions 6 08-31-2010 08:39 PM
Defog window recap greenmax General DIY Discussions 4 05-07-2010 05:00 PM
