Home Built In 1860 - Leaking Basement B/c Of A Compromised Foundation - Building & Construction - DIY Chatroom Home Improvement Forum
Old 11-04-2011, 06:01 AM   #1
LBS
Home built in 1860 - leaking basement b/c of a compromised foundation
The basement is wet b/c the water is getting in. The foundation is big stones from the creek held together with mortar. What are the options in repairing?
LBS is offline   Reply With Quote
Old 11-04-2011, 07:50 AM   #2
Ironlight's Avatar
I think we're going to need a bit more information in order to give you any useful advice. Is the foundation stable but just allowing water in? Has there been recent settling? How long has it been in its current state? Is the floor paved or dirt? When you say "repaired", are you looking to simply make the basement dry? What do you want to make the basement suitable for, functionally?
Ironlight is offline   Reply With Quote
Old 11-04-2011, 11:59 AM   #3
Rewards Points: 1,766
Step one: regrade ground outside to get water away from home; direct downspout water at least 5' or more.
bob22 is online now   Reply With Quote
Insulating basement of split level home. mmastran Building & Construction 23 08-24-2011 06:19 AM
Crack Between Basement Slab and Foundation cweb2ny Building & Construction 15 06-01-2011 04:59 AM
New Home - Foundation Issue, need advice, pease help ... nbreau Building & Construction 11 03-14-2011 04:39 PM
basement still leaking AFTER doing tile/gravel drain annie68164 Building & Construction 2 03-12-2010 07:22 AM
subpanel mounting on concrete basement foundation wall bulk88 Electrical 12 03-10-2009 01:38 PM
