Home Addition Foundation Too Low - Building & Construction - DIY Chatroom Home Improvement Forum
Old 05-15-2012, 08:53 AM   #1
Home addition foundation too low
I'm planning an addition to my ranch home that currently has 2x8 floor joists. My current foundation is about level with grade. Is there a way I can raise the new foundation so that the outside of the foundation will be above grade while using 2x12 floor joists in the addition? I was thinking along the lines of a reversed brick ledge. Any ideas are greatly appreciated.
rhoffman26 is offline   Reply With Quote
Old 05-15-2012, 09:04 AM   #2
Framing Contractor
You use 12" block below grade set to allow for the height of the new joists ....mudsill and sill sealer. Starting at grade you use 8" block flush to the outside of the 12" block. This creates a 4" shelf on the inside where your floor joist will sit.
This is done all the time in low grade situations like this.
Joe Carola
Joe Carola is offline   Reply With Quote
Old 05-15-2012, 09:29 AM   #3
Residential Designer
AndyGump's Avatar
Rewards Points: 684
Send a message via Skype™ to AndyGump
Yes there is a way to do this (provided I am understanding you correctly), you will need a designer to draw something up for you to get permits though.
Andy.
Residential Drafter/Designer
www.draftinginoc.com
AndyGump is offline   Reply With Quote
Old 05-15-2012, 12:05 PM   #4
So you're saying 12" block to get the floor to the proper height and then frame the floor. After that set 8"block and set the wall on that? Thanks for your help
Old 05-15-2012, 12:12 PM   #5
AndyGump's Avatar
Rewards Points: 684
I am not saying that at all as I do not fully understand what you are trying to do. Npr do I know how your present foundation is biult.
Andy.
Old 05-15-2012, 12:24 PM   #6
Rewards Points: 528
That is one way.
framer52 is offline   Reply With Quote
Old 05-15-2012, 01:19 PM   #7
Rewards Points: 502
I wanted to lower the floor on my porch turned sun room. Original joists were 2x4s (notched down to 2x1a at one end ). I wanted at least 2x6s since I was thinking marble flooring. I bolted a PT 2x8 to the inner wall of the foundation as a ledger board, and then used a 2x12 as a beam on the other side (not at a foundation wall)
what I'd do is size it so it comes even with the when you slap a PT 2x6 on top of the outer and inner foundation. I believe you never put non-rot resistant wood on concrete.
forresth is offline   Reply With Quote
Old 05-15-2012, 02:03 PM   #8
Just a DIY guy
I believe you should also put a sill sealer between the concrete and the PT wood.
http://www.reflectixinc.com/basepage...&PageIndex=627
http://www.protectowrap.com/energy-s...y-sill-sealer/
M3 Pete is offline   Reply With Quote
Tags
foundation , framing
grading foundation around our home ralphiemom Landscaping & Lawn Care 1 05-10-2012 06:41 PM
Attaching addition to existing home G-Mo Building & Construction 4 02-10-2011 06:15 PM
Basement addition foundation questions hoggin03 Building & Construction 7 05-29-2009 07:28 AM
Addition Foundation /Build. advice wannabuild Remodeling 3 12-15-2006 06:28 PM
Home Addition cost? Russ Chewning Building & Construction 3 10-23-2006 07:59 PM
