Home Addition ??? - Building & Construction - DIY Chatroom Home Improvement Forum
Old 03-19-2004, 05:35 PM   #1
Home Addition ???
DOES ANYONE KNOW HOW HIGH A CRWLSPACE MUST BE. I THOUGHT IT WAS 28 INCHES BUT NOT SURE. I LIVE IN NJ AND REMAMBER HEARING SOMTHING ABOUT A CRAWL SPACE MUST BE HIGH ENOUGH FOR A FIREFIGHTER AND AIRPACK TO FIT ??THANKS MTCOOP@COMCAST.NET
mtcoop is offline   Reply With Quote
Old 03-19-2004, 05:49 PM   #2
Talking
I have been a contractor for 25 years and this is without a doubt a new one on me. I'm just so ammused that this even a thought, let alone made to an actual post. This is not an attack on the original post but a opinion on a relatively funny piece of info.
Check your local building codes
Contact your local fire dept
I have never seen or heard on any firefighter putting out a house fire from underneath
Ron in Southern Md. is offline   Reply With Quote
Old 03-23-2004, 10:41 PM   #3
Contractor
Urban legend.
Teetorbilt is offline   Reply With Quote
Old 03-25-2004, 08:12 AM   #4
Grumpy's Avatar
Rewards Points: 540
Send a message via AIM to Grumpy Send a message via MSN to Grumpy Send a message via Yahoo to Grumpy
To know for sure call your local building dept. They will tell you for sure.
-Grumpy http://www.illinoisroofinspections.com
The information found in this post is not to be considered legal advice. The author of this post takes no responsibility for any losses that occur. Use at your own risk.
Grumpy is offline   Reply With Quote
Old 12-16-2005, 06:09 AM   #5
28'' is the proper min. head space for a scuttle access into the attic .. As far as a standard Dim. for a crawl space ?
You got me on that one ....when you find out let me know .
Thanks Don
djames is offline   Reply With Quote
Old 12-17-2005, 01:00 AM   #6
renovations
That's the number and the reason given for it here.
Bonus is offline   Reply With Quote
Old 12-17-2005, 08:02 AM   #7
The "universal building code" that I tested on had a 18" dirt to wood requirement. I ran into the same problem a few years back and could not find a good answer. I would think a crawler should be big enough for an inspector to do an inspection although I have only seen an inspector in a crawler 1 time and he didn't go out of the access area. Maybe the IRC has something and someone will come along to straighten us out. HS. > I made my last crawler 6' because I'm 5'11". Bigger is better in my opinion.
K2eoj is offline   Reply With Quote
Shed type roof addition on Brick home? sandyman720 Roofing/Siding 6 04-24-2007 02:35 PM
Home Addition cost? Russ Chewning Building & Construction 3 10-23-2006 07:59 PM
