-   -   Home Addition ??? (http://www.diychatroom.com/f19/home-addition-132/)
mtcoop 03-19-2004 05:35 PM
Home Addition ???
DOES ANYONE KNOW HOW HIGH A CRWLSPACE MUST BE. I THOUGHT IT WAS 28 INCHES BUT NOT SURE. I LIVE IN NJ AND REMAMBER HEARING SOMTHING ABOUT A CRAWL SPACE MUST BE HIGH ENOUGH FOR A FIREFIGHTER AND AIRPACK TO FIT ??THANKS MTCOOP@COMCAST.NET
Ron in Southern Md. 03-19-2004 05:49 PM
I have been a contractor for 25 years and this is without a doubt a new one on me. I'm just so ammused that this even a thought, let alone made to an actual post. This is not an attack on the original post but a opinion on a relatively funny piece of info.
Check your local building codes
Contact your local fire dept
I have never seen or heard on any firefighter putting out a house fire from underneath
Teetorbilt 03-23-2004 10:41 PM
Urban legend.
Grumpy 03-25-2004 08:12 AM
To know for sure call your local building dept. They will tell you for sure.
djames 12-16-2005 06:09 AM
28'' is the proper min. head space for a scuttle access into the attic .. As far as a standard Dim. for a crawl space ?
You got me on that one ....when you find out let me know .
Thanks Don
Bonus 12-17-2005 01:00 AM
That's the number and the reason given for it here.
K2eoj 12-17-2005 08:02 AM
The "universal building code" that I tested on had a 18" dirt to wood requirement. I ran into the same problem a few years back and could not find a good answer. I would think a crawler should be big enough for an inspector to do an inspection although I have only seen an inspector in a crawler 1 time and he didn't go out of the access area. Maybe the IRC has something and someone will come along to straighten us out. HS. > I made my last crawler 6' because I'm 5'11". Bigger is better in my opinion.
