Hollow Or Solid Core Door For Pocket Door - Building & Construction - DIY Chatroom Home Improvement Forum
Old 08-30-2010, 10:05 AM   #1
hollow or solid core door for pocket door
I am looking for any pros or cons on using a solid core door or hollow core door in a pocket door install.
RobertN is offline   Reply With Quote
Old 08-30-2010, 11:32 AM   #2
Totally screwed together
If you care at all about sound deadening, use a solid door.
xxPaulCPxx is offline   Reply With Quote
Old 08-31-2010, 10:53 PM   #3
Rewards Points: 177
It also depends on the type of pull you will be using. If it is the type where you need to notch the edge of the door, then you need to use a solid door.
paul100 is offline   Reply With Quote
Old 10-12-2015, 02:36 PM   #4
Rewards Points: 14
i know this discussion is dead, but in case anyone comes in via google like i did. solid core doors weight a lot more than hollow, so look at the tracks you'll be buying with it. some tracks support more weigh than others.
bob13bob is offline   Reply With Quote
Old 10-12-2015, 07:55 PM   #5
journeyman carpenter
woodworkbykirk's Avatar
Rewards Points: 1,214
ive used both without issue. just depends on the look your going for. ill use solid doors for bathrooms specically for sound reasons
woodworkbykirk is offline   Reply With Quote
That hollow door nopicnic General DIY Discussions 9 07-11-2010 09:08 PM
Storm Door Selection/Brand Advice Wanted kc27 General DIY Discussions 3 10-25-2009 08:17 AM
Painting Interior Hollow Core Doors shapeshifter Painting 3 03-07-2007 10:01 PM
Hanging towel bar in hollow core door. ERIK2173 Remodeling 1 02-06-2006 07:19 PM
