Hollow Floor - Building & Construction - DIY Chatroom Home Improvement Forum
Old 02-15-2012, 01:38 PM   #1
hollow floor
Since I had a drain system installed in my basement, the area where they broke ground sounds very hollow. Naturally because they installed the system but I'm concerned that any excessive weight like a "dressed wall" will cause the floor to give way and crack... Any incite?
WAINSWURLD is offline   Reply With Quote
Old 02-15-2012, 01:54 PM   #2
Rewards Points: 13,458
No idea what a "dressed wall" is.
If you mean a wall with drywall over it there's not that much weight per square inch and the 2 X 4 helps spead out the load.
WAINSWURLD (02-15-2012)
Old 02-15-2012, 06:02 PM   #3
journeyman carpenter
woodworkbykirk's Avatar
Rewards Points: 1,114
joes right, if its a partition wall dont worry about it. however if this is a bearing wall it needs to be addressed. via jackhammering out the concrete and putting ina proper footing then patch the slab
woodworkbykirk is offline   Reply With Quote
The Following User Says Thank You to woodworkbykirk For This Useful Post:
Old 02-15-2012, 06:50 PM   #4
I hear ya, thanks. I think what raised a flag for me the most was that the installer told me that my original floor thickness was 4" but after he installed everything, he said there was only a need to put back about 2" of concrete. Obviously, you never know how good a contractor's work is gonna be until after he's done working...
Termite wood floor as sub-floor gtimk4 Flooring 1 09-21-2011 06:30 PM
Dryer duct hole thru band joist & floor joist justplumducky General DIY Discussions 12 10-05-2010 12:31 PM
2nd floor air flow/pressure fgillis HVAC 7 02-24-2009 04:58 AM
Levelling wood floor gomi_otaku Building & Construction 13 11-27-2008 07:45 AM
Old old linoleum, can it take paint? molamola Painting 23 11-11-2008 06:32 PM
