Holey 2x10 Due To More Plumbing Follies - Building & Construction - DIY Chatroom Home Improvement Forum
Old 01-24-2009, 02:04 PM   #1
Holey 2x10 due to more plumbing follies
Here's part 2 of the plumbing rough in debacle.
They initially installed my Woodford V22C horizontally instead of vertically. Then they cut it out and installed a horizontal model.
As a result, I now have a bunch of holes in a 2x10. This bathroom was originally a back porch, and the perimeter was double 2x10s running to concrete piers.
The 2x10s were partially chewed (years of termite abuse), so a carpenter installed new 2x10s around the perimeter before hanging joists. Thus the beams around the perimeter are now tripled.
Here's the damage:
Is this OK or does it need some kind of reinforcement?
pmoe is offline   Reply With Quote
Old 01-24-2009, 02:27 PM   #2
First fire the plumber, then you've got some work to do. Is this a single plate?
Chemist1961 is offline   Reply With Quote
Old 01-24-2009, 02:52 PM   #3
Too late to fire the plumber.
The 2x10s you see with the holes are three-ply.
Old 01-24-2009, 02:57 PM   #4
Geeze .....You need KCT or someone on your codes here and tighten up the loose wiring I think. What's with the wet pipes in this pic?
Old 01-24-2009, 05:10 PM   #5
Registered User
Termite's Avatar
Although ugly, there's not really any problem with the holes the way they are. The code allows you to drill a hole with a diameter not to exceed 1/3 of the joist's actual depth. You're also required to leave 2" of wood intact top and bottom no matter how big the hole is.
Based on what I see I think you're just fine.
As for the wires, they're ugly, but that's a topic for another thread!
Old 01-24-2009, 09:11 PM   #6
BUILDER / REMODELING CONT
buletbob's Avatar
PMEO!!!! I feel for you. I just came across this post. you should of posted this with the other, these guys should be shot. Sloppy solder joints. but you should be fine with the holes. BOB
Want to tile bathroom - raise plumbing? wombosi Plumbing 2 11-13-2008 07:54 PM
plumbing a new sink kchiasson Plumbing 1 09-23-2008 03:04 PM
missed the plumbing in the slab!!! fauer Plumbing 7 03-03-2008 07:37 PM
Connecting new plumbing into existing plumbing Just do it guy Plumbing 2 02-18-2008 09:36 PM
new plumbing in kitchen What have I done Plumbing 1 07-29-2006 11:14 AM
