Holes In Floor Joist - Building & Construction - DIY Chatroom Home Improvement Forum
Old 02-16-2010, 08:16 PM   #1
CNMDESIGN.COM
Holes in floor joist
Putting a new water and electrical system in my home. I would like to run two ¾” pex lines from one end to the other through the joist along with a run for electric. The three runs will run perpendicular to the 2x10 joist, 16” on center with a span of approx 15’. Where do I put the holes? I would like to run along the outside wall just above the block wall for the basement, put I think that’s a no go.
CNM Design is offline   Reply With Quote
Old 02-16-2010, 08:36 PM   #2
jlhaslip's Avatar
Rewards Points: 2,134
That should be okay.
Drill the holes as close to the centre line as possible, max of about 2" diameter.
3/4 " would likely be enough for the wire, and 1 1/4" for the 3/4" pex.
Not sure if you can run them in the same hole, though. Might be better to run 3 holes with space between them.
Short of cutting off a body part, the worst that can happen in woodworking is manufacturing really nice looking kindling. --- Quoted from lenaitch
jlhaslip is online now   Reply With Quote
Need help caulking and filling nail holes in my trim hadees Painting 13 11-25-2012 10:32 PM
Block Foundation w/Hundred Seep Holes? Jodust11 Building & Construction 9 04-13-2010 10:41 AM
Drilling Multiple Holes in Studs rjschwar Building & Construction 6 01-27-2010 01:05 PM
Interior: Preserving Installation Screw Holes During Skim coating? Lovegasoline Building & Construction 4 09-29-2009 03:03 PM
Holes in tree NightOfDiscovery Landscaping & Lawn Care 6 08-30-2009 04:39 PM
