Old 01-20-2013, 01:12 PM   #1
Hole in Wooden Exterior Door Jam
Hello All From Fredericksburg, VA
I just bought a home built in 1975. In spite of having the home inspected, I'm discovering a few things I need to address.
I just noticed the wooden sliding glass door has a large hole in it on the exterior which is pretty substantial. Hole in Wooden Exterior Door Jam-016.jpg I can't afford to replace the door now but would like to fill it with something to prevent further damage.
Is there an epoxy I can use?
Thanking you in advance.
momof2labs is offline   Reply With Quote
Old 01-20-2013, 01:28 PM   #2
Civil Engineer
There are several varieties of wood filler or epoxy you can use. In all cases, it is necessary to remove rotten wood to get back to reasonably good condition wood. If it is impossible to find decent wood, you can try using wood hardener (a liquid designed to harden rotten wood) as a temporary fix for the rotten wood.
Personally I have had pretty good luck with Minwax two part epoxy filler. A little pricey, but it is easy to work with. It sounds like you understand that filling the door is a temporary fix, but it might hold you for a year or two.
Old 01-20-2013, 05:55 PM   #3
Hi Daniel:
Thanks for your quick response.
I have always had good luck with Minwax. When you're fixing a serious problem, the expense is secondary. I also saw Gorilla is making an epoxy for wood, too. That's the one I bought but haven't used it yet so I may return it.
I went to Lowe's and got an estimate for replacement doors. The SLD would cost about $2500 plus $500-700 or so for installation. (There's 2 double SGD side by side). Needless to say, I won't be using this home inspector again.
Warm Regards from Fredericksburg, VA
Donna
Old 01-20-2013, 06:55 PM   #4
It is not that hard to do yourself for a glass door. With some skill you could actually take the door apart and make a new piece on a router table.
paintdrying is offline   Reply With Quote
Old 01-20-2013, 07:39 PM   #5
Average Joe/ex-Navy IC3
gregzoll's Avatar
Something that old, and that bad, it is easier to replace the door. Repairing it will slow the process, but the door still needs to be replaced in the long run.
: Now listen, Cadet. I've got a job for you. See this button?
: Don't touch it! It's the History Eraser button, you fool!
: So what'll happen?
: That's just it. We don't know. Maybe something bad, maybe something good. I guess we'll never know, 'cause you're going to guard it. You won't touch it, will you?
Old 01-21-2013, 10:03 AM   #6
Windows & Dogs
Taylor Rae's Avatar
does the door slide right now with all that rot? It looks like it's rotted where the rollers are. We've been using Car Bond-O for wood repairs for many years. Lowe's has it, so does pep-boys
Taylor Rae is offline   Reply With Quote
Tags
wood filler, wood rot
patching hole in 8" concrete block BlueBSH Building & Construction 5 08-09-2011 07:55 PM
Need to enlarge hole in wood top plate: or use flex with minimum OD. mysterylectric Electrical 3 08-09-2011 03:52 PM
Large hole in wooden support beam a problem? mephisto Building & Construction 5 07-18-2011 12:36 PM
Sump hole and water drain questions Ncasalejr Plumbing 1 06-21-2011 10:57 AM
Cutting out a hole on a stainless steel sink...pics Goldglv General Discussion 14 02-28-2010 11:04 PM
