Hole In The Wall - Help Please! - Building & Construction - DIY Chatroom Home Improvement Forum
Old 11-10-2005, 04:07 PM   #1
Hole in the Wall - help please!
hi! i really need some emergeny DIY help!
I am a complete novice at this and have no idea what I am doing.
There is a hole in my wall. its a plasterboard wall and the hole hasn't gone into the other room on the other side just through to the insulation. It's about 20-30cms round, so not very big but it's really noticeable.
I need to get rid of it asap!
what is the easiest and cheapest way for me to fix it?
thanks!
Kaye is offline   Reply With Quote
Old 11-10-2005, 11:13 PM   #2
aka:awesomedell
Rewards Points: 150
Send a message via MSN to housedocs
Hi Kaye and welcome aboard.
If the hole isn't too large you can simply repair it with a piece of screen mesh and some joint compound. If it's much over 3" or 4" in diameter, should just cut it out square and repair it with a small piece of drywall and some backer boards.
Is this a smooth finished wall or is it textured? If it's textured you can probably patch it up well enough not to be noticed, but if it's a smooth wall, you might want to find a local drywaller or handyman to patch the hole for you.
If you'll do a search for "drywall or sheetrock repair" there are several threads with instructions on hole patching available. Post back if you still have questions.
All you need is ignorance and confidence and success is assured. - Mark Twain
housedocs is offline   Reply With Quote
Old 11-11-2005, 11:35 PM   #3
Contractor
House, It sounds like someone had their head stuffed through the wall. Nothing like a good party!!
Cut out all of the old busted stuff and look inside. Respond with actual hole size. undamaged and relative stud locations.
Teetorbilt is offline   Reply With Quote
Old 11-12-2005, 11:07 PM   #4
Contractor
KenTheHandyMan's Avatar
Rewards Points: 150
Kaye,
If you're still needing some help, I'm throwing a step by step together for you at http://www.home-improvement4u.com/wa...all-repair.htm
Regards,
Ken Walker
KenTheHandyMan is offline   Reply With Quote
Old 11-12-2005, 11:18 PM   #5
Contractor
Rewards Points: 150
Step by Step Hole Repair
I figured I'd just throw this in here and see if it stirs up a bunch of confusion! I wasn't sure if I'd get all the steps done before too long, and I'm tired, so I'm just posting the images. Think of it as mime.
4 image limit!!!
Regards,
Ken Walker
Old 11-12-2005, 11:18 PM   #6
Contractor
Rewards Points: 150
Regards,
Ken Walker
Old 11-12-2005, 11:19 PM   #7
Contractor
Rewards Points: 150
Regards,
Ken Walker
Old 11-12-2005, 11:19 PM   #8
Contractor
Rewards Points: 150
An important note here, the piece I'm adding is glued to the backer material.
Regards,
Ken Walker
Old 11-12-2005, 11:20 PM   #9
Contractor
Rewards Points: 150
This doesn't include the remaining coats of mud. I've also used cardboard as a backer before, but I really don't think it is solid enough. If somebody bangs the same spot again, it will just need to be fixed again. This solution gives some solid stability long term.
Regards,
Ken Walker
Old 11-12-2005, 11:25 PM   #10
Contractor
Rewards Points: 150
Basically, straighten the edges. Remove any debri or shredded paper from the back of the hole. Cut a scrap of wood that will fit in the hole (make it a good 6 inches longer than the length of the hole). You'll have to use your own judgement on the width aspect.
I used string to hold the piece until the adhesive set. You could use screws but I only had a hardwood scrap and didn't want to fool with trying to screw into it. You stand a chance of popping out more rock that way as well. You twist the string/stick combo until it is tight.
Cut a piece to fit the now straightened hole (well, fairly straight). Glue it in place. Bed of mud and tape the seams. Make sure to squeeze out any bubbles.
Regards,
Ken Walker
Old 11-12-2005, 11:26 PM   #11
Contractor
Rewards Points: 150
I almost forgot, I scored the perimeter and peeled away the paint so that I will be able to feather into the repair better.
Regards,
Ken Walker
Old 11-16-2005, 03:26 PM   #12
Rewards Points: 150
Cool repair Ken, just like I would have done it, oops have done it I guess!!
justdon is offline   Reply With Quote
Old 11-16-2005, 10:50 PM   #13
Nice visual walk through Ken.
I am curious why not just screw the board in place?
JustaFramer is offline   Reply With Quote
Old 11-16-2005, 11:06 PM   #14
Contractor
Rewards Points: 150
I guess I have done it that way before but this particular scrap was oak and getting the one screw in it to hold onto it was tough enough. I didn't want to risk trying to hold the piece and put a screw in and dropping the board
Regards,
Ken Walker
Old 11-17-2005, 01:26 AM   #15
Makes perfect sense. :D
Hole in new construction basement wall AprilQ Building & Construction 5 07-08-2008 07:14 PM
Hole in wall w/ stress cracks... lots of detailed pics (NOT 56k connection friendly) Thaipo Building & Construction 8 05-21-2007 07:40 AM
Atlantic-need your opinion on markd's comments about my vapor barrier? yummy mummy Building & Construction 11 03-07-2007 10:47 AM
Load Bearing Wall? Traybae Remodeling 3 11-05-2006 02:39 PM
How do I drill the hole in the wall if I don't know location of electrical wire popkadurak Remodeling 10 06-16-2006 11:06 AM
