#1 |
hole size for anchoring PT plates with 0.5" bolts
i am anchoring PT plates for my 11x9 shed with 0.5" bolts into concrete. was wondering which size SDS-plus drill bits i should use to drill the holes. i need exact size cause these bits ain't exactly cheap (cca $25) so i'd rather not buy two for experimenting (gotta be frugal these days). 5/8 makes a tighter fit with anchoring epoxy but i was thinking to go all the way 3/4 to make more room for epoxy for strength. please advise.
thanks |
#2 |
Why not use something like these on this link:
http://www.bestnutsbolts.com/anchors.html No worries about epoxy and sizing. |
#3 |
You can use this system: http://www.ucanfast.com/products/details.php?category=Chemical+Anchors&c=3&subcateg ory=Anchoring+Cement+%26+Glass+Capsules&sc=176&pro ductid=137
Part # HAC 12 Size M12 x 95 Treaded Rod Dia. ½ Drill Size 9/16 Hole depth for rod 4 We use these all the time Or you can just use a 9/16 sds drill bit for your ½ anchor but make sure it is a wedge anchor or like you suggested using a Ύ sds drill bit but now you have to use something like rockite self leveling and patching cement with your ½ dia. Threaded rod with a nut and washer. We have used all of these and had no problems with them. |
#4 |
I am using the most regular decking bolts, 1/2x6. I do want to use anchoring epoxy, i.e. not just screw it snug. I would test with 5/8 first but I sort of wanna avoid testing different drill bit sizes as I just wanna use the perfect size as I am on a budget and don't wanna buy more than the only one that's the perfect choice. They cost $25 each ... Please advise.
#5 |
DIY Hack
There is such a thing as too much epoxy. and not all epoxies are the same ( some aren't even really epoxy). best bet is to follow the mfg's recomendations for bolt size and hole size. make sure you blow and/or vacuum the dust from the holes
Those who can, do... Those who can't criticize on the internet |
| Display Modes | |
| Problem Patching Large Drywall Hole | FuLLTiLT | Drywall & Plaster | 5 | 11-21-2009 10:42 PM |
| Using sharkbite to fit leak in pipe...pipe hole size question. | RyanD | Plumbing | 4 | 08-14-2009 07:17 PM |
| Door knob hole size discrepancy | janralix | Carpentry | 8 | 08-04-2009 09:11 PM |
| power-actuated nail size for sole plates | amakarevic | Building & Construction | 4 | 06-03-2008 02:12 PM |
