Old 12-17-2005, 01:18 PM   #1
Default Hole in new construction basement wall
Hi. I need some advice. I am building a new home with a large developer. Our footings and basement walls were poured in the last week in freezing temps and lots of snow.
There is a hole approximatly 2' x 2' in the middle of one of the basement walls. It has obviously been patched. The builder does not seem that concerned, but I am. Is this a major compromise of the integrity of the structure? The hole penentrates all the way through the wall. They have offered water proofing in the basement and a 10 year warrenty.
Any advise is appreciated. I have pictures of the hole.
AprilQ is offline   Reply With Quote
Old 12-17-2005, 03:09 PM   #2
I would want a letter from a professional engineer from your state regarding the structure. Water is a tough one on a cold joint in concrete. Depending on drainage, ground water etc. you may never have a problem but I would be concerned on that one.
They had snow in the bottom of the forms and thought the mud would melt it and push it to the bottom and out. I've seen really bad cases of that situation which engineers would sign off on. I'd be upset if it were my house.HS>
K2eoj is offline   Reply With Quote
Old 12-17-2005, 09:58 PM   #3
Default Thanks
Thanks for the advice. I am planning on requesting an evaluation from an idependent engineer and I'm also calling the building inspector.
Old 12-20-2005, 08:21 AM   #4
a lot of walls are poured in cold weather so weather shouldnt be an issue. i am curious as to what happened. i have seen wall cut-outs for egress windows, or small basement windows, or even tubes put in for some utilities to pass through. find out from your builder who did the walls and see what the problem was. i dont think this will be a compromise of the wall itself, but i am concerned about how well the patch job is. post us some pics.
THEBIGPUNN is offline   Reply With Quote
Old 07-08-2008, 08:08 PM   #5
Phil
Too bad it was a small hole as it might have been useful for a furnace vent line. I would want the hole patched with the proper type of concrete product to control moisture and air penetration. I would do it myself or hire a third party and not trust the contractor or one of his subs.
Your local building inspector should have a clue as to why it is there in the first place. I would suspect a screwup by the person doing the forms work for the concrete pour.
I would not proceed until the problem is resolved and question the integrity of your contractor based on your description of his response to the matter. This was a visible flaw that you caught. What about the ones that will be buried in the walls or attic?
Phillysun is offline   Reply With Quote
Old 07-08-2008, 08:14 PM   #6
Building codes guy, Mod
thekctermite's Avatar
You do realize that this is a three year old post, don't you?
thekctermite is offline   Reply With Quote
More On This Topic
If you've had trouble insulating your home from hot summer weather, you might consider investing in an attic fan. While air conditioning can help to cool air in the livable portions of your home, most attics do not have air conditioning. After hours of... Read More »
So now were coming into the part of the home that we haven’t yet completed. This is the path to the guest bedroom. This stairwell was a closet. Now you can see that the walls have been sheetrocked and some of the tape has gone on the nail holes... Read More »
Bathroom Design Ideas
Bathroom Design Ideas by Expert Village
When I met with the homeowner he told me where he wanted to build his new bathroom and what he wanted to have in it and where he wanted to have it. Originally he wanted the toilet where I am standing and I told him I thought it would be better in the... Read More »
Hi I am Drew Fendy, master home inspector. I have been inspecting for over 24 years. Today we are going to describe how to install an electrical receptacle for Expertvillage.com. Okay, now we need to drill a hole from the basement up through into the... Read More »
Hole in wall w/ stress cracks... lots of detailed pics (NOT 56k connection friendly) Thaipo Building & Construction 8 05-21-2007 08:40 AM
basement wall insulation around electric breaker box tvoltz Building & Construction 0 03-31-2007 01:16 AM
Atlantic-need your opinion on markd's comments about my vapor barrier? yummy mummy Building & Construction 11 03-07-2007 11:47 AM
Conduit through basement wall. bdalekid Electrical 13 01-31-2007 10:35 PM
Basement wall Problem dazusa Building & Construction 2 01-20-2005 11:16 AM
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
