Hole In Floor Joist. - Building & Construction - DIY Chatroom Home Improvement Forum
Old 11-16-2012, 04:59 PM   #1
Hole in floor joist.
Repair five inch hole in 9 x 1-3/4 inch floor joist, inspector wants it the length of basement.
Lukata is offline   Reply With Quote
Old 11-16-2012, 05:07 PM   #2
Rewards Points: 12,802
Ok, so is there a question in there someplace with the little but of info you provided?
Old 11-16-2012, 05:10 PM   #3
Master General ReEngineer
Bondo's Avatar
Rewards Points: 334
Ayuh,.... 'n how long might That be,..??
Bondo is online now   Reply With Quote
Old 11-16-2012, 05:12 PM   #4
Residential Designer
AndyGump's Avatar
Rewards Points: 660
Send a message via Skype™ to AndyGump
The length of the basement...
How long is the basement?
The same length he needs the floor joist.
I hope this helps.
Andy.
Residential Drafter/Designer
www.draftinginoc.com
AndyGump is offline   Reply With Quote
Old 11-16-2012, 09:29 PM   #5
Rewards Points: 150
Sistering the joist the full length with it bearing at both ends is a prescriptive method. If you want to do less, that would be engineering a fix and the Inspector will likely tell you to have a design professional, e.g. licensed architect or engineer, specify that fix. It is easier and more economical to just sister the joist the full length with it bearing on both ends.
TheCamper is offline   Reply With Quote
Old 11-16-2012, 10:04 PM   #6
Rewards Points: 6,652
Let me guess, Home Inspector? If it is a building inspector for the city or county, you are at their mercy and have to do what they say. If it is a HI, tell them to show the documents backing up their statement.
Really need to post pictures showing this. Make sure that you stand back and do not zoom on the joist with the hole, just take a picture and post showing the surrounding area with that 5" hole and associated joists.
Old 11-17-2012, 05:58 PM   #7
Rewards Points: 502
Whether or not the 5" hole seriously weakens the joist depends on its position along the span. Quite probably, there is no structural need to sister the joist along the whole span but, as you have been advised, that would be cheaper than getting a SE to prove by calculation that whole-length sistering wasn't structurally necessary.
tony.g is offline   Reply With Quote
Repair Small Hole in Vinyl Siding Silkcityflorida General DIY Discussions 12 04-08-2013 04:34 PM
Cutting Hole for Bathroom exhaust jburchill Kitchen & Bath Remodeling 14 04-16-2012 12:55 PM
patching hole in 8" concrete block BlueBSH Building & Construction 5 08-09-2011 07:55 PM
Need to enlarge hole in wood top plate: or use flex with minimum OD. mysterylectric Electrical 3 08-09-2011 03:52 PM
How to patch hole in duct work and drill new one? Studly HVAC 10 03-03-2009 10:26 AM
