Hole Diameter Size In Floor Joist For Data Cable - Building & Construction - Page 2 - DIY Chatroom Home Improvement Forum
Old 07-04-2012, 11:02 AM   #16
Rewards Points: 502
Originally Posted by Breakingcustom View Post
Your speaking Chinese to me with span tables and what not.
He was advising you on a critical factor to be taken int account when drilling or notching joists which may already be near their safe-span limit.
tony.g is offline   Reply With Quote
Old 07-04-2012, 12:39 PM   #17
Rewards Points: 6,652
I'm not running standard Cat6 cable. I got leftover cable from a project and it is all Panduit Cat6 plenum so it's not as small as regular Cat5e.
It is not that much larger. Run bundles of at least six per 5/8 hole, and you will do fine. I sure would not pull one large bundle, and end up with a two inch hole, which would be unprofessional way of doing it.
Old 07-07-2012, 10:42 PM   #18
Rewards Points: 1,225
I'd consider a more distributed network design. Add a switch here, a switch there, and significantly reduce the number of wires to run.
dalepres is offline   Reply With Quote
Old 07-08-2012, 08:01 AM   #19
That is not how to properly do a distributed network design. What the OP is doing, is how it is commonly done. Only time you would put a switch here or there, is if you have a large network spanning multiple floors. Then you want to use smart switches and patch panels on each floor, then run a backbone down to the main network equipment room.
Old 07-08-2012, 08:57 AM   #20
Actually it is how to design a network. I am a network engineer and have done this many, many times, in businesses and in homes. In a business scenario, you need smart switches and patch panels. You can install one per floor, or you can install one for multiple floors or one per seating area that might support a handful of folks. It just all depends on the layout of the building, difficulty in running wires, length of cables, distance between buildings, etc.
In a residential scenario, you don't need smart switches at all. Simple 50 dollar gigabit switches installed in each "zone" of the house would be perfect. Using smart (or managed) switches at home does not make sense at all. While a home-run wiring with a patch panel would give a look that you could show off how cool and industrial looking your network room is, there is no technical advantage to that. You can simply plug directly into the switch. That would mean, assuming 8-port switches, a maximum of 8 cables in any single run. This is much more structurally friendly to the house.
Old 07-08-2012, 10:27 AM   #21
The OP is not going to just do networking, it is for structured A/V controls along with hdmi for remote equipment with hdtvs. May want to read the beginning, then just jump in with a different idea.
Yes there are various ways of doing things, but your idea does not work for this job.
Hole size in stud for DVW pipe spring3100 Plumbing 3 12-20-2011 01:18 PM
Cable Size for Sub Panel vs chart jamiedolan Electrical 5 11-09-2008 01:30 PM
Cable size advise needed makulos Electrical 3 10-22-2008 11:13 AM
Allowed to run more than one romex cable through a single hole in a joist? J187 Electrical 7 08-17-2007 08:46 AM
Coaxial Cable Question bahaisamurai Home Theater 9 08-08-2007 02:54 PM
