Old 03-28-2008, 11:31 PM   #1
hole in brick
Is it better to core or can I stick with roto hammering a hole in my brick fireplace. I want to replace my old hearth stove but can only afford a standard wood stove so I want to drill a new hole through the face of the bricks slightly larger than the diameter of a new chimney pipe then attach it to the chimney liner. What do you think? The hole will either be 6 or 8 inches.
bigredone is offline   Reply With Quote
Old 03-28-2008, 11:43 PM   #2
hole in brick
Rotohammering might cause vibration issues with the surrounding masonary. I would probably drill a series of holes as a release to reduce the vibration transmission to the rest of the wall. Many older chimney's have soft, deteriorated mortar.
Ron
Old 03-29-2008, 08:37 AM   #3
conc repr & dec conc
Send a message via AIM to dec-conc-artisan Send a message via Yahoo to dec-conc-artisan
hole in brick
bit & core it dry using 1/2" 550rpm drill if you can't locate 1, use a carbide-tipp'd masonary bit - but no hammering as you're likely to damage surrounding brick's stability al a ronnie's suggestion
dec-conc-artisan is offline   Reply With Quote
Old 03-29-2008, 05:00 PM   #4
hole in brick
what if I were to just cut 2 lines up each side of the already existing openin makin it taller? then I would not have to make a hole. would that change anything as long as I stayed within the same size of the already existing square that is there?
20 year old Brick Wall Repair Bobrobert General Discussion 15 11-22-2011 04:07 PM
How to repair a hole in cast Iron pipe? bofusmosby Plumbing 26 11-13-2011 10:35 AM
A Hole to Nowhere fw2007 Electrical 12 03-24-2008 11:28 AM
How to drill a 4" hole into brick for a vent??? firemanpato General Discussion 10 01-17-2008 09:00 PM
Making an 8" hole in the brick Hushpuppy Building & Construction 6 11-28-2006 08:17 AM
