A Hole In The Basement Wall - Building & Construction - DIY Chatroom Home Improvement Forum
Old 01-07-2009, 10:44 PM   #1
Rewards Points: 150
A hole in the basement wall
I'm getting ready to finish a part of my basement. Today I was cleaning some minor effluescence off the poured concrete outside wall when I came across this hole. It seems to have dirt in it and I can probe a good 6 inches into it. Good news is it's probably been there a long time and shows no indication of having taken in any water.
I thought I'd fill it in with some kind of watertight cement patch and go on with my dry lock sealant, vapor barrier...etc.
So what do you all think? OK plan? any suggestions on patching material? And lastly, how the heck does somethingA hole in the basement wall-imgp2558.jpg like this happen?
I'm gonna hurl myself against the wall
because I'd rather feel bad than not feel anything at all
Warren Zevon
handifoot is offline   Reply With Quote
Old 01-07-2009, 11:00 PM   #2
Learning by Doing
Leah Frances's Avatar
Dictyoptera Portlandis infestation. Call an exterminator.
Get it? Concrete Termites
If I could only remember to THINK about what I was doing before I did it.
Leah Frances is offline   Reply With Quote
Old 01-07-2009, 11:47 PM   #3
Can't really tell from that photo what is going on there... Can you post a better shot?
Reilley is offline   Reply With Quote
Old 01-07-2009, 11:48 PM   #4
Rewards Points: 150
uhhhh.....OK
Anyone with some constructive advice?
Warren Zevon
Old 01-07-2009, 11:50 PM   #5
Rewards Points: 150
Reilley, that last post of mine was not about you. I'll try to get a better picture. Thanks
Warren Zevon
Old 01-08-2009, 12:03 AM   #6
Rewards Points: 150
Maybe this is a little better pic. It's about 1.5 inch high in the center and about 7 inches side to side. It looks wet because I discovered it while I was washing the wall.A hole in the basement wall-imgp2561.jpg
Warren Zevon
Old 01-08-2009, 07:47 AM   #7
i'd wait til it dries & ck again visually & by ' sounding ',,, if it sounds hollow, chip out & patch as you post'd,,, if nothing happens, patch anyway,,, hydraulic's as good as anything else + you can buy small amts.
yesitsconcrete is offline   Reply With Quote
Old 01-08-2009, 07:55 AM   #8
Not so new
12penny's Avatar
Rewards Points: 520
handi....on a different note, are you doing anything with the floor? Those appear to be asbestos floor tile and should be tested for same before removing.
Have fun.
12penny is offline   Reply With Quote
Old 01-08-2009, 08:06 AM   #9
BUILDER / REMODELING CONT
buletbob's Avatar
If its a poured concrete wall then It appears to me when they poured the wall there could of been dirt at the bottom of the form which kept it from forming properly. and over time the dirt was cleaned away. BOB
Old 01-08-2009, 10:13 AM   #10
Rewards Points: 150
12 penny,
Thanks, I already thought about that. It's intact and I'm not going to disturb it.
I'll be covering it with either laminate or carpet.
Warren Zevon
Old 01-08-2009, 10:14 AM   #11
I agree. Hydraulic cement is fairly easy to work with (mix, stir, kneed, stuff). You can prepare the spot with a mallet and a cold chisel. Chip out the crack to form a > shape with the small side out. Hydraulic cement expands as it cures and this shape allows it to grab rather than push itself out of the hole. The instructions are pretty clear on the container.
Basement Wall Mortar rory535 Building & Construction 16 08-06-2009 10:39 AM
what should I be careful about when drilling a hole through in the wall. foxwood Remodeling 3 08-25-2008 05:17 PM
damp basement wall. itguru Building & Construction 7 12-16-2007 06:02 PM
Dirt along wall in basement? Beren General DIY Discussions 20 07-01-2007 04:53 PM
Basement wall Problem dazusa Building & Construction 2 01-20-2005 10:16 AM
