Hole For Basement Bathroom Vent Location - Building & Construction - DIY Chatroom Home Improvement Forum
Old 04-10-2009, 08:07 AM   #1
hole for basement bathroom vent location
Just wanted some opinions on cutting the 4" hole for bathroom vent. I was going to relocated the outside water gate valve and just make the 4" hole in that location. Just wanted to make sure that it is ok to do this in this location marked in red. It's not a joist so not sure if the D/6 rule applies when boring in the outside wall plate.
jeeper is offline   Reply With Quote
Old 04-10-2009, 08:46 AM   #2
Registered User
Termite's Avatar
I would have little concern about putting the hole for the vent through the rim joist. It is done that way all the time. Boring rules could still be applied but the rim joist isn't in span so as long as you aren't drilling under a load point (trimmer studs supporting a window header, etc) you're good.
I'd recommend a circular hole just to be safe though.
Old 04-10-2009, 08:55 AM   #3
Thanks,
It isn't under load point such as you mentioned windows etc. This is just the outside wall rim joist. I figured that it must be done like this just didn't know how you would get around it if they hole boring code applied for a none span joist 2x8. Thanks.
Old 04-11-2009, 09:56 PM   #4
Registered User
Rewards Points: 5,498
Make sure to insulate it, so moisture won't condense in the pipe before it goes out.
Question: Is the joist over the plastic tubing sticker tag - - sagging? It may be my eyes. If so, I'd lift it flush and put a hanger on.
Be safe, GBAR
Old 04-12-2009, 11:25 AM   #5
Extensions
it will be better to use an adaptor instead of 4 inch hole. However - to me it looks like a load wall bearing and if it is - then it is safe to do it.
extensions is offline   Reply With Quote
Vent location for bathroom exhaust fan slapdash Remodeling 5 06-26-2012 10:38 AM
Cutting Vent Hole in Roof How To Wanted wildbilly Plumbing 17 06-02-2010 04:35 AM
Bathroom vent directly over a rafter Kirgan Roofing/Siding 6 03-11-2009 01:30 AM
Venting bathroom vent thru dryer duct jredrocker HVAC 2 09-27-2008 10:25 PM
Bathroom Vent Not Vented to Outside / Would need to vent through flat roof House_Amuck HVAC 5 03-30-2007 09:57 AM
