Hip Roof Info - Building & Construction - DIY Chatroom Home Improvement Forum
Old 06-10-2009, 12:03 AM   #1
Hip Roof info
Help on placing a hip roof on a 14 X 14 garage. Start to finish.
Over hang 12 inches. Walls are up.
nbickham is offline   Reply With Quote
Old 06-10-2009, 01:09 AM   #2
I moved this from the Roofing sub-forum to carpentry for you.
I don't know, maybe building and construction would have been just as good or even better, but lets see if you get the responses you need here.
Ed
Ed the Roofer is offline   Reply With Quote
Old 06-10-2009, 08:43 AM   #3
Rewards Points: 5,336
You really need a framing book to get the basics understood. There's no way you will get enough detailed information solely from here to do the job.
A hip roof involves a very complex assortment of compound cuts and angles. About the most difficult roof to frame.
What experience do you have in roof framing?
Ron
Old 06-10-2009, 01:01 PM   #4
Registered User
Rewards Points: 5,188
This will get you started: http://books.google.com/books?ei=8h0...G=Search+Books
Just click on the books with "Limited preview" in color below each. A lot of good info and most of it is accurate. Be safe, G
Gary in WA is online now   Reply With Quote
Old 06-10-2009, 02:51 PM   #5
Rewards Points: 1,910
Here's some good resources for calculating your framing
http://www.josephfusco.org/Calculato...alculator.html
http://www.blocklayer.com/roof/RoofEng.aspx
http://www.construction-resource.com...roof-frame.php
Old 06-10-2009, 08:33 PM   #6
Here`s a linl to a rafter table that you may find handy!
http://www.geocities.com/PicketFence...ftertable.html
Old 06-11-2009, 10:52 AM   #7
BTW, With a square garage (14x14) you wont have a ridge on top unless you use 2 different slopes. So two of your hip rafters will meet at the peak and the other two will set against the first two. The two that meet will be 3/4" longer since they rest against each other rather than against a 1 1/2" thick ridge board.
Old 05-22-2012, 05:20 PM   #8
PPBART's Avatar
Rewards Points: 303
Thought I would resurrect this old thread to ask if any of y'all use this calculator? I'm building an outdoor kitchen (more like a screened in 10'x14' rectangular gazebo) and used this calculator for the hip roof design. The ridge and common rafters fit perfectly, but the hip rafters seem to be off by about 1"--1.5" . Is there some gremlin in the program, or am I just missing something somewhere?
UPDATE: I found the problem... I had reprinted the calculation sheet and neglected to properly enter the pitch.; didn't realize 5/12 vs 6/12 would make such a difference(!)
PPBART is offline   Reply With Quote
Old 05-22-2012, 10:28 PM   #9
Rewards Points: 940
One trick I can offer for the first two rafters on a hip roof which has no ridge is to put a bit of strap connecting the rafters. Then Hold them up until they are stuck together and sink a screw or nail in.
cleveman is offline   Reply With Quote
The moving Ice Dams after using a roof rake ?? Canufixit Roofing/Siding 9 02-05-2009 08:33 PM
Flat roof questions, advice, ballpark estimate JerryH Roofing/Siding 18 11-07-2008 05:08 PM
Flat roof - Rolled? - leaks Advice? JJ2001 Roofing/Siding 4 11-19-2006 07:17 AM
