Hip Rafter Connection Details - Building & Construction - DIY Chatroom Home Improvement Forum
Old 07-12-2009, 10:15 AM   #1
I have gas!
Clutchcargo's Avatar
Rewards Points: 1,374
Hip rafter connection details
I've been building a small addition to the top of my sunroom and I've come to the point where I'm starting to build the roof. The house has a hip main roof and the builders in 1925 just loaded it up with nails. Is that still an acceptable method of attachment?
Does anyone have an illustration of hip rafter connection details?
I've been thinking about this and how I'd do it is:
1st. Install the center common (how to attach?)
2nd. Cut the two side commons (4 nails in each)
3rd. Cut 2 45 on each hip (4 nails in each? how to attach?)
I tear things down and build them up.
Clutchcargo is offline   Reply With Quote
Old 07-12-2009, 11:44 AM   #2
SNC
Yes much of the time roofs are just nailed togeather at the top.
some use clips simalar to this http://store.qualitydist.net/sst-l50.html
some of them can be bend to various angles.
when i nail i use 2 nails 2x4
3 nails 2x6
4 nails 2x8
5 nails 2x10 ect...
SNC is offline   Reply With Quote
Old 07-12-2009, 02:33 PM   #3
Registered User
Rewards Points: 526
As SNC said, nail them. Unless in a high wind or seismic area, Check with local B.D.
http://www.strongtie.com/products/connectors/hcp.asp
http://www.strongtie.com/products/connectors/hrc.asp
http://books.google.com/books?ei=8h0...G=Search+Books Over 100 pictures, click on Limited preview books. Be safe, G
Tags
connection , hip rafter
Telephone Jack Connection Problem jogan Electrical 9 04-20-2009 06:10 AM
Moving Attic Access -- Same Rafter or Different ?? wrldruler Carpentry 1 10-19-2008 06:03 PM
need some rafter help feralfreak Carpentry 5 07-30-2008 06:48 AM
rafter questions - structural rtoni Carpentry 11 09-13-2007 05:40 AM
