Old 08-10-2012, 08:29 AM   #1
Hints for cutting J-channel
Any hints you can share for cutting the j-channel around windows? I am finding it difficult to get the corners neat.
I am installing Certainteed Insulated siding.
paullo is offline   Reply With Quote
Old 08-10-2012, 09:27 AM   #2
A "Handy Husband"
rjniles's Avatar
I use a pair of straight tin snips. You can also but the pre-made corners. They come in different colors.
http://www.lowes.com/pd_20238-40958-NHCWH08_0__?productId=3053163&Ntt=vinyl+siding+acc essory&Ns=p_product_price|0
Coastal South Carolina
rjniles is offline   Reply With Quote
Old 08-10-2012, 10:23 AM   #3
The insulated siding uses 1 1/4" j-channel. The premade corners don't work with the wider j.
Old 08-10-2012, 01:19 PM   #4
Architectural Designer
AGWhitehouse's Avatar
http://inspectapedia.com/BestPractices/Figure1-25.jpg
Life's too short...so enjoy it!
AGWhitehouse is offline   Reply With Quote
Old 08-10-2012, 01:29 PM   #5
http://www.amazon.com/Malco-JCC-8-In.../dp/B00004SUQZ
JonM is offline   Reply With Quote
Old 08-10-2012, 03:43 PM   #6
$50!!!!!! Regular shears or tin snips work just the same for a fraction of the cost and they are useful for other projects...
Old 08-11-2012, 10:20 AM   #7
tack the pieces up and over lap them and cut both at the same time. or mark with your speed square and cut. i also leave the top piece a bit long on both sides and cut a mini drip edge.
princelake is online now   Reply With Quote
Old 08-11-2012, 02:23 PM   #8
Toool is not worth the expence if you are doing one house...but for production, well worth the cost
The Following User Says Thank You to JonM For This Useful Post:
mae-ling (08-11-2012)
Old 08-13-2012, 10:59 AM   #9
Fair enough, but the OP doesn't sound like they'll be doing production runs...
Old 08-13-2012, 07:46 PM   #10
Tom Struble's Avatar
op is using insulated siding that uses a 1 1/4'' wide pocket,pretty challenging to work with for a diyer
op post some pics of the ones you have done
Tom Struble is offline   Reply With Quote
asphalt/concrete joints and a channel drain wolderiii Building & Construction 0 08-26-2011 11:02 AM
Help! Casings around window with integrated J channel? Learn2Build Remodeling 8 06-01-2010 06:10 PM
How-To: cut a channel in concrete? vsheetz Building & Construction 7 01-31-2009 02:21 PM
How to install resilient channel on ceiling Bcoleman6 Building & Construction 1 08-22-2008 03:29 PM
Channel Modulator BigE Home Theater 4 11-11-2007 09:15 PM
