-   -   Hints for cutting J-channel (http://www.diychatroom.com/f19/hints-cutting-j-channel-153216/)
paullo 08-10-2012 07:29 AM
Any hints you can share for cutting the j-channel around windows? I am finding it difficult to get the corners neat.
I am installing Certainteed Insulated siding.
rjniles 08-10-2012 08:27 AM
I use a pair of straight tin snips. You can also but the pre-made corners. They come in different colors.
http://images.lowes.com/product/conv...47000168sm.jpg
http://www.lowes.com/pd_20238-40958-NHCWH08_0__?productId=3053163&Ntt=vinyl+siding+acc essory&Ns=p_product_price|0
paullo 08-10-2012 09:23 AM
The insulated siding uses 1 1/4" j-channel. The premade corners don't work with the wider j.
AGWhitehouse 08-10-2012 12:19 PM
http://inspectapedia.com/BestPractices/Figure1-25.jpg
JonM 08-10-2012 12:29 PM
http://ecx.images-amazon.com/images/...500_AA300_.jpg
http://www.amazon.com/Malco-JCC-8-In.../dp/B00004SUQZ
AGWhitehouse 08-10-2012 02:43 PM
$50!!!:eek:!!! Regular shears or tin snips work just the same for a fraction of the cost and they are useful for other projects...
princelake 08-11-2012 09:20 AM
tack the pieces up and over lap them and cut both at the same time. or mark with your speed square and cut. i also leave the top piece a bit long on both sides and cut a mini drip edge.
JonM 08-11-2012 01:23 PM
Toool is not worth the expence if you are doing one house...but for production, well worth the cost
AGWhitehouse 08-13-2012 09:59 AM
Fair enough, but the OP doesn't sound like they'll be doing production runs...
Tom Struble 08-13-2012 06:46 PM
op is using insulated siding that uses a 1 1/4'' wide pocket,pretty challenging to work with for a diyer
op post some pics of the ones you have done
