Hilti SMD57 Screw Gun Attachment - Building & Construction - DIY Chatroom Home Improvement Forum
Old 12-30-2011, 07:53 PM   #1
I picked one of these up for my SD2500 screw gun and cannot figure out how it works. The instructions are of little help.
I got it set up per the instruction and when I try to drive a screw it just wobbles around in the track when I try to push in.
I thought the screw would remain rigid until the bit hit the screw and that is not the case. If you are the least bit out from straight when trying to drive a screw the screw cants in the track and makes it un-drivable.
Anyone have any suggestions on how to use it properly?
Thanks,
Steve
Sierevello is offline   Reply With Quote
Old 12-30-2011, 07:59 PM   #2
Rewards Points: 14,020
Are you 100% sure the right bit for that screw is in it?
The only trick I use is to not pussy foot around when installing the screw. To little pressure or backing off when pushing down and it will mess up.
Slam bam thank you mamm and move on to the next screw.
Old 12-30-2011, 09:52 PM   #3
retired union carpenter
Send a message via Yahoo to coupe
the trick to any screw gun, is to keep it straight!
as always, just my thoughts
good luck....coupe/Larry
take what helps? ignore the rest.
coupe is offline   Reply With Quote
Stuck Screw IceTreay General DIY Discussions 11 09-09-2010 01:56 PM
Azek Decking and Cortex Screw System EdtheC Flooring 2 08-27-2010 07:48 PM
Swapping old 3ways with new (different screw color configuration on new switch) Michblaze02 Electrical 10 11-08-2009 02:17 PM
Can't get set screw in TP holder loose janralix Plumbing 4 08-12-2009 10:47 PM
Doorknob attachment to spindle c2gene General DIY Discussions 6 10-26-2008 05:04 AM
