High Water Table Footings - Building & Construction - DIY Chatroom Home Improvement Forum
Old 03-22-2013, 05:49 PM   #1
Fester
High water table footings
My building is going to be 40'x45' on 10' concrete walls 10" wide above ground i live by a lake so the water table is high. how wide and deep should the footings be to support the walls
staff is offline   Reply With Quote
Old 03-22-2013, 05:57 PM   #2
Rewards Points: 13,712
The building inspector or the person that's going to doing the foundation should be able to tell you this.
No way any stranger on a website that's never been there should be telling you the depth or width.
If you need to be asking this then you should not be building your own foundation.
Done wrong and the rest of the house is doomed.
Old 03-22-2013, 06:07 PM   #3
Fester
Post
Thanks Joecaption just trying to find out if the contractor is filling me with BS
Old 03-22-2013, 06:15 PM   #4
What did he suggest?
Old 03-22-2013, 06:18 PM   #5
Fester
Thanks Joecaption just trying to find out if the contractor is feeding BS
Old 03-22-2013, 06:21 PM   #6
Fester
12"wide x 30" deep
Old 03-22-2013, 06:32 PM   #7
Makes no since to me to have them that narrow and so deep but wait until som of the concrete guys chime in.
The wider the foot print the less it's going to sink.
No idea why that depth is needed.
I also live in a low laying area right on the bay and for a single store we have 8" deep X 24" footing with three pieces of rebar even for a two story.
But hay I'm not a full time concrete guy.
Old 03-22-2013, 07:08 PM   #8
Fester
Thanks again He said it was a frost free footing It gets cold here in Missouri
Low hot water pressure crebive Plumbing 38 02-26-2013 12:26 AM
Water heater solutions to get hot water in timely manner daluu Plumbing 22 05-07-2012 08:44 PM
Water seepage under my footings Jaycorr Building & Construction 2 09-08-2011 09:25 AM
Solar hot water indatom123 Green Home Improvement 0 12-19-2010 12:01 AM
High water table upmaroon Plumbing 13 07-30-2010 09:25 PM
