High Humidity Inside My House - Building & Construction - DIY Chatroom Home Improvement Forum
Old 06-22-2010, 03:03 PM   #1
high humidity inside my house
my house is almost 3 years old. i have not had this problem until three weeks ago. the humidity level is at 88%. i can cool the house down and bring the humidity down some, but it will rise again as soon as i turn the a/c up.
Last edited by mfinley; 06-23-2010 at 04:12 PM. Reason: i need this to be moved to hvac
mfinley is offline   Reply With Quote
Old 06-22-2010, 04:03 PM   #2
Rewards Points: 340
this should be in the hvac forum. check your a/c condensate pan/drain (attic, basement or closet), make sure there is no standing water in the pan from a clogged or partially clogged drain. make sure there is good airflow over the coil, could be a dirty coil or a dirty air filter. could also be the coil freezing over due to low airflow and/or low system charge.
NitroNate is offline   Reply With Quote
The Following User Says Thank You to NitroNate For This Useful Post:
mfinley (06-22-2010)
Questions about jacking up house to replace rotted rim/sill SolidStateS15 Remodeling 10 03-22-2010 11:43 AM
High humidity (RH) spm25 HVAC 3 11-06-2009 07:50 AM
EXcessive moisture in house geema HVAC 5 09-10-2008 11:18 AM
Complete AC installation in Old Capitol Hill Row House jacko10 HVAC 0 09-18-2007 05:42 PM
How cool should it be inside the house? beer_geek HVAC 8 05-13-2007 01:42 PM
